2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes *REVIEW* KW Coilovers- Variant 3 (V3) for F10 5 series
      07-22-2011, 08:10 AM   #23
wheeladdicts
wheeladdicts's Avatar
Drives: E90 M3
Originally Posted by eNma View Post
tnx, and offsets?
I can't release that as it took a lot of work to get it right. If you decide to purchase they will be released to you.
      07-22-2011, 10:31 AM   #24
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
2011 F10 528i  [10.00]
Originally Posted by mlai View Post
Wheels circumference quite a bit larger than stock size. Any issues?
Originally Posted by remmib View Post
Not really, only about 1%.
Yup, shouldn't have much difference. Could be a problem if it's 255/35/21
295/30/21
2011 F10 528i Black Sapphire / Oyster Black
2000 E46 325ci Cabrio Titanium Silver / Black - retired
1997 E36/7 Z3 Montreal Blue / Black - retired
      07-22-2011, 11:53 AM   #25
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
Well, what is right really? I'm not sure this was, as I believe they were so aggressive that luigimaster24 is getting 5mm shaved off the hub to increase the offset.
      07-22-2011, 11:55 AM   #26
wheeladdicts
Drives: E90 M3
You are right Luigi had rubbing but Luigi picked his own offsets because he wanted to go as aggressive as possible. The original offset suggestion was what he reverted to
      07-22-2011, 11:36 PM   #27
luigimaster24
luigimaster24's Avatar
Mexico
159
Drives: 2020 X7 M50i & 2021 X6M Comp
To anyone that wants to know what offsets I went with on the Forged 1 Wheels.
Fronts: 21x9 et25
Rears: 21x10.5 et35
I definitely had some rubbing issues on the rear considering I was slammed on KW V3's, however, the rubbing was minimal when I had them at the H&R spring ride height.
      07-23-2011, 12:40 AM   #28
mlai
mlai's Avatar
Hong Kong
170
Fronts: 21x9 et25
Rears: 21x10.5 et35
But you still had rubbing with H&R. A bit too aggressive.....
E93 M3 Cabriolet Satin Pearl White/CR - 2012/03/12 Bilstein PSS10/ Michelin PSS 245/35R19-265/35R19 Brembo GT
2011 F10 550i M Sport - Retired
      07-23-2011, 03:11 AM   #29
luigimaster24
Mexico
159
Yes Mlai, Still HAD rubbing with the H&R springs, although it rubbed only on very big dips with aggressive driving.
      07-23-2011, 03:04 PM   #30
eNma
Drives: f10
Fronts: 21x9 et25
Rears: 21x10.5 et35
BIG tnx so i need 40+ @ rr to no rub? yeah?
      07-23-2011, 06:40 PM   #31
wheeladdicts
Drives: E90 M3
This was before removing the 5mm. Using the Forged 1 recommended offsets you will not rub assuming a 255/39/21 and 295/25/21.
20x10.5 et35 = rubbing
21x10.5 et40 = no rubbing
For reference the wheels you picked up are the equivalent of 20x10.5 et42 so you will not rub. On 20" the tires have more sidewall so a less aggressive offset is required.
      07-24-2011, 06:20 AM   #32
remmib
remmib's Avatar
Norway
1568
Fronts: 21x9 et25
Rears: 21x10.5 et35
Thanks for sharing.
      08-02-2011, 07:29 PM   #33
rmastale
Drives: F10 535i MSport, F15 X5 MSport
I have a question on the KWs; or any coilover for that matter. When adjusting the height (drop); i assume you have to take the wheels off each time? So the initial trial and error might consist of 3-4 on/offs of the wheels?
      01-08-2012, 05:42 PM   #34
luigimaster24
Mexico
159
Yes, i would remove the wheels to adjust the height.
      07-24-2012, 08:25 PM   #35
JRDM
Drives: 2012
Quick ???....are the KW3's yellow springs visible at all? Thanks
      07-24-2012, 10:21 PM   #36
luigimaster24
Mexico
159
Nope..
      07-26-2012, 06:36 PM   #37
Tam@SupremePower
Tam@SupremePower's Avatar
2007 e92 335i  [7.00]
Nice write up !
      08-13-2012, 07:38 PM   #38
edongF10
edongF10
edongF10's Avatar
China
Drives: 535Li 2012
Hi guys, may i ask how come after taking off the the original suspension from my 535Li i discovered there's no wires or anything ?i think there must be something that may connect to the sport or comfort mode?i'm installing the V3 and i'm a little confused.did i miss something or what? Coz i think it's kinda impossible.kinda wierd.
      08-22-2012, 07:00 PM   #39
edongF10
edongF10
edongF10's Avatar
China
Drives: 535Li 2012
I finally came around and set some time aside, to deliver my personal review for the KW Coilovers- Variant 3 for our BMW 5 series F10.
Initially, my interest in the KW’s was only to attain the height drop that H&R springs couldn't deliver for my F10. However, I quickly found out that KWs are so much more than just a solution for a lower stance on your vehicle. I drove my F10 long enough on stock suspension, too long on H&R sport springs, and gave myself enough time to experience the KWs to be able to share my first impressions and lasting impressions on them.
Stock F10 Suspension ( Non DHP/Adaptive drive)
Most, if not all of us know what the stock suspension on the F10 feels like, unless you modified your suspension on day 1. The feeling of the stock suspension on the F10 is like a floaty boat ride which makes you feel alienated from the road. Tight cornering on my F10 with stock suspension was not pleasant, as the body roll was enough to throw my wife and I from side to side like we were doing the chicken dance. The floatiness and loose feel of the car, combined with the altitude at which my F10 stood consequently led me to swap out stock springs for H&R sport springs in hope of improved ride quality.
H&R Springs
H&R sport springs definitely helped make the F10 feel more planted, and cosmetically improved the F10’s look by lowering it a little over an inch overall. However, I was not completely satisfied with the springs for although the floatiness improved, it still remained, especially on the freeway and at higher speeds. The ride on the H&R springs was still jumpy and took a few seconds to settle back down after going through a dip . Cornering on H&R springs was definitely better than stock, although body roll still lingered enough to be very noticeable and uncomfortable when spirited driving took place. The height drop was acceptable from the H&Rs considering the price, and the ride was ok aside from the floatiness at high speeds and the lag in stabilization after a significant dip. H&Rs still left me expecting more from my BMW F10, which led me to decide on making the best investment I’ve made on my F10 as of yet. KW Coilovers.
KW Coilovers V3
The day I drove back to San Diego from Trinity Autosport after installing the KW V3’s on my F10, I simply felt like I was driving a completely different vehicle (from a ride quality stand point). My car felt planted to the ground and feedback from the road was drastically improved. Taking turns at 80mph felt like turning at 25mph, total comfortably, completely stable, and connected to the road. Going over dips where the springs compress and decompress, the car stabilized itself in a matter of milliseconds compared to H&R springs and stock where you are kept floating up and down until stable. Nose diving when braking quickly and hard was gone, the car comes to complete clean stops without jerking you or your passengers forward.
I would mention any downsides to the KWs, but IMO, there aren’t any.
I am currently dialed in at factory out of the box settings and have not played with the dampening or compression. I am very satisfied with the feel of the car and enjoy every moment driving the F10. Everything I tried to improve with H&R springs and couldn’t attain has now been completed with KW coilovers, which are definitely worth every penny.
KW coilovers are not for the faint of heart and if you don’t really care about performance, stability and complete versatility of the ride and height of your vehicle, than I would say springs or stock suspension would do you just fine.
However, If your’e looking for an aggressive suspension that TRULY performs, drastically improves the quality of your ride, totally enhances the look of your F10, and can be adjusted to the height of your liking, then KW coilovers were made just for you.
Here's a video I made showing off a few F10's on KW V3's
Stock Suspension Pictures
H&R Springs Pictures
KW Coilovers V3 Install @ Trinity Autosport (Thanks Joe and Nerwyll)
KW V3 Suspension Pictures
Hi, may i ask an advice from you guys?well 'm using a v3 suspension and i felt its very stiff i tried to drive my car fon an hour and got a headache, what do you think is the proper settings or adjustments? Is it the rebound or what?is it 5 or 6? It's like riding in a racing car so stiff that we keep on bouncing inside the car
      08-22-2012, 07:06 PM   #40
edongF10
edongF10
edongF10's Avatar
China
Drives: 535Li 2012
H&R Springs
KW Coilovers V3
Would you mind to share your setting like height and stiffness? Both are default box settings?
      08-22-2012, 07:10 PM   #41
edongF10
edongF10
edongF10's Avatar
China
Drives: 535Li 2012
H&R Springs
KW Coilovers V3
      11-05-2012, 10:17 PM   #42
Cpluse2
Drives: BMW 2010 535i
I have to say this was a great thread to read. I just got a 2010 535! (E60) 1st BMW. Lovin it. But i feeling that very bumpy and want more control and shock absorption. This thread was very helpful. I think i will order KW street comfort. Since i wont be racing on any track but still want that tightness and control. I think the hardest part is finding a company where i live to install it the correct way.
      06-27-2015, 03:54 AM   #43
matowi
matowi's Avatar
Poland
260
Drives: '24 X5 M60i
2024 X5 M60i  [0.00]
Originally Posted by bobblehead
Absolutely A+ for the write-up.
I am sold on this but have to wait for the Xdrive version to come out. My shop guy says KW is still doing final stage testing now and production should begin late summer and ready for market distribution in the late fall.
In a recent conversation (June 2015) with a local dealer I was told that KW finally released the V3 suspension for x-drive F10.
Have any of you out there heard similar news? Any views on whether it would be a good idea to install this set up?
I have so far followed the path of the topic author and installed H&R sports springs on my 535, which rides on stock suspension with no DHP/AD.
And, as much as I like the way the car has improved with the new springs, there is still a lot to be desired (handling, floatiness)
Have: '24 G05 M60i
Had: '15 F10 535d; '21 G11 740d
      07-11-2015, 11:21 AM   #44
hsrashid5
Road Killer
Drives: 2018 M5 F90
Im running H&R's on my 2012 535Xi and its perfect. i wanted to go coils but i have edc, and etc. so I'm not sure if they came out with a model for xdrive and with dec control. The H&R's are doing justice with my Vossen VFS-2. Front-20x9(245) Back-20x10.5(275)
Haseeb
Current Daily Drivers: 2018 BMW M5 F90 Alpine White/ Aragon Brown Full Merino Leather, 20" M Double-Spoke Black, Formula1 15% Tints
Retired: 2012 535Xi Carbon Black, Meisterschaft GTS Quad Exhaust And ETC
