2010 2011 BMW 5 Series Forum F10 312 wheels 20inch with AcS springs/ tire question |
11-08-2017, 07:49 PM | #1 |
Rep 17
Hi everyone
Have a 535xi 2015 Will these tires size work with my combo 245 40 20 front 275 35 20 rear Would it create a better ride or am I better of with the one reckless tyres Thanks for your help |
11-09-2017, 11:48 AM | #2 |
Rep 697
Drives: 2013 535xi
Interesting timing. I've just put on my oversized winter 245/50/18 tires onto my ACS-lowered 535xi. They rub the front fenders when I hit bumps. I'm not sure if this is caused by the oversized tire and lack of top clearance with the ACS springs or the aggressive offset making the oversized tire too flush with the fender (or maybe it's caused by both) but it raises a potential red flag to your question. My front wheels are 18" x 8" with effective ET of 26mm (ET 41 with 15mm spacer - it's a long story but last winter my winter wheels/tires without spacer started rubbing on the front suspension even before the car was lowered so I left on the spacer required for my summer front wheels when I switched to the winter wheels with an effective ET of 26).
Cheers.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) Last edited by cdmulders; 11-10-2017 at 05:31 AM.. |
11-09-2017, 10:38 PM | #4 |
Rep 5,140
11-10-2017, 05:34 AM | #5 |
Rep 697
Drives: 2013 535xi
Fair enough. For four winters, my 245/50/18 winter tires never rubbed at all. Only the lowering and now offset of 26mm (on 8" wide wheel) seems to cause rubbing. I'm not sure where it is rubbing, but it is definitely tire vice metal that is doing the rubbing. Are you lowered?
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
11-11-2017, 10:42 AM | #7 |
Rep 17
Thanks, since it's lowered would it cause any rubbing.. could it cause an issue with speed or odometer reading.. how about any possible issues on the differentials
Trying to go from 245/35/20 to 245/40/20 or 255/35/20- front 275/30/20 to 275/35/20 or 285/30/20 back Would either be good or can it create an issues |
11-11-2017, 10:56 AM | #8 |
Rep 5,140
285 is too much for the rear 9" wheel.
I recommend 245/40 and 275/35. The speedo will be close to perfect with the taller tires since it is optimistic with OEM tires. |
11-12-2017, 04:57 PM | #9 |
Rep 1
I disagree that 285 is "too much" tire for the rear on stock rims. What is your logic? Is there going to be rubbing? I highly doubt it. Is it a handling/safety issue? Eh no, that's not it either. But I agree if you don't want your speedo to be off to make sure you get the correct overall diameter of tire.
11-13-2017, 12:36 AM | #10 | |
Rep 5,140
I'm sure it can actually be fitted, but it's not recommended and will bulge alot. Having too much bulge will influence handling since the tire may distort when cornering. 285/30- 20 has 10" wheel width as recommendation, 9.5" and 10.5" as alternatives. |
