2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Sport Package and Tire Wear
      11-13-2013, 08:10 PM   #1
Diesel_Lover
Drives: 335d
I have been told that with larger wheels and sports suspension that tires wear out at under 20,000 miles.
Do tires wear out that quickly with sports package?
Assuming what I have been told is true, will this happen with DHP, as well?
      11-13-2013, 10:05 PM   #2
raleedy
Drives: 2016 228i 6-speed
A lot depends on how you drive the car, and how you maintain the tires. Bigger wheels (19" or 20" for example) mean more expense: greater wear, higher vulnerability to damage from curbs and potholes, and higher replacement costs. Although it's admittedly a lighter car, my E92 with sport suspension and 18" wheels got a bit more than 30,000 miles from the OEM set of run-flat tires.
      11-14-2013, 02:06 PM   #3
mness
Drives: 2013 535iM
Sport suspension packages usually will come with sport/summer tires, which wear quicker because they have stickier rubber. So I don't think it's the suspension per se, just dependent on what model tire you have. All-season tires will last longer than max performance summer tires in the same size on the same car.
      11-14-2013, 05:22 PM   #4
Diesel_Lover
Drives: 335d
O.K. that makes sense. The tread wear rating is lower on soft gummy sports tires.
