2010 2011 BMW 5 Series Forum F10 Removing front struts on xDrive 535's |
05-19-2020, 12:18 PM | #1 |
Rep 175
Is it possible to remove front struts from a F10 535 xDrive without removing the upper a-arm bolts? I do not have Electronic Damping Control. I'm planning on installing lowering springs in my driveway using standard jack stands. Thanks.
05-20-2020, 08:05 AM | #3 |
Rep 1,873
Yes, but IMO the procedure is even worse than loosening the upper arm:
https://www.newtis.info/tisv2/a/en/f...truts/ByUPTXkE Take a look at the coilover DIY threads - all the same work. |
06-09-2020, 02:02 PM | #4 |
Rep 13
06-09-2020, 06:59 PM | #5 | |
Petrolhead
440
Rep 809
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
+1
Followed this video the first time I installed the Dinan springs and will soon be doing it all over again with the V3s install. The only thing you SHOULD NOT follow is how they failed to use a spring compressor. Always use a spring compressor. Always. Quote:
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) |
