2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding PIC: iDrive/Nav Screen Too Easily Scratched.
      04-15-2013, 02:02 PM   #1
NYF32DRIVER
NYF32DRIVER's Avatar
Drives: 2016 428i X Drive
I finally took a pic of the damage to my screen. I still have no idea how it happened. Once again, I feel the screen is STUPIDLY delicate and I know that many of you agree and have had similar issues. It is always somewhat visible and only looks THIS bad in bright sunlight:
PS- Please do not bother with replies like: "Never happened to me" or "Mine still looks like new" I am looking for constructive solutions here.
Thanks, Joseph
2016 428i X Drive. Mineral Gray Metallic. Born 2/2016, Munich Factory.
Member BMW CCA Since 2008
      04-15-2013, 02:07 PM   #2
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
Have you talk to your dealer about this issue?
      04-15-2013, 02:52 PM   #3
NYF32DRIVER
"We won't even TOUCH those iDrive screens" was the answer I got from the Hassel SA and Service Manager.
      04-15-2013, 05:28 PM   #4
OzDriver
OzDriver's Avatar
Australia
Drives: '13 535i & '08 530i
I looked for a way to remove scratches from my old iPad screen, and all the recommended methods seem to involve using a very, very fine abrasive cream of some sort. I guess the idea is that you buff out the visible scratches with something that makes even finer scratches that you can't see
I never used any of these ideas as they seemed likely to do more damage than they repaired, but you can find them by Googling something like "removing fine scratches from plastic screens".
      04-15-2013, 08:29 PM   #5
NYF32DRIVER
It's not a scratch, the Anti-Glare coating RUBS OFF very easily leaving the highly reflective surface underneath exposed. I guess thats why my previous FOUR BMW's all had protective plastic in front of the NAV or iDrive screen.
      04-15-2013, 10:32 PM   #6
Atombyte
Atombyte's Avatar
Drives: 2013 M3, 2016 535i, 2019 540i
2019 540i  [0.00]
2016 535i  [0.00]
2013 M3  [0.00]
Our 2011 X5 iDrive has a few scratches on it also. It came from our first few cleanings. Changed over to the soft, electronic screen cleaners like you'd use on laptop screens and it didn't degrade any further.
      04-15-2013, 11:19 PM   #7
BMWrules7
Drives: 2015, 740 LdX, Alpine White
Thanks, Joseph
Agreed. BMW uses the term "saves added weight" as an analog to "cheap plastic, easily scratched."
      04-16-2013, 03:49 AM   #8
Terpinator
Terpinator's Avatar
Netherlands
10
Drives: 550i xDrive M Sport
Joseph, that sucks! I feel for you....
I thinking about only using compressed air "dusters" (often used to clean computer keyboards) to clean my screen. Has anyone had a problem using a compressed air can to blow the dust off the screen?
      04-16-2013, 07:04 AM   #9
BMWrules7
Yes. Never used those dusters unless they are made specifically for a camera lens. The non-camera lens dusters can contain contaminants that will sandblast the surface you are spraying.
The best method is to use 2 new MF towels. Wet one with filtered water. Then wipe wet one back and forth in side to side motion---no circular motions.
Then take dry towel and quickly wipe wet marks of with one stroke.
      04-16-2013, 09:59 AM   #10
ManiacGT
ManiacGT's Avatar
Drives: Z4 sDrive 35i
Wow now I understand what you mean. I don't know of any products that would replace the anti glare coating, but it might be worth looking online. Its that, or a new iDrive screen (eek)..
      04-16-2013, 10:06 AM   #11
NYF32DRIVER
$2000 to replace the screen... without labor !
      04-16-2013, 10:22 AM   #12
remmib
remmib's Avatar
Norway
1568
That gotta be the whole unit.
      04-16-2013, 08:29 PM   #13
NYF32DRIVER
Yep... another great design decision by BMW.
      04-17-2013, 09:38 AM   #14
ManiacGT
ManiacGT's Avatar
I had a quick look on realoem.com. They list 3 part numbers for this screen, with different dates, looks like they improved it over time?
http://realoem.com/bmw/showparts.do?...10&hg=65&fg=45
01 Central information display 10" 1 03/2011 65509243897 ENDED
01 Central information display 10" 1 09/2011 65509241826 ENDED
01 Central information display 10" 1 07/2012 65509266385
But lets say its the latest screen (at least that's what you'd want to replace it with if its compatible)... a UK price for that component alone is £1,787.44 + vat = £2144.40 which a quick google to USD is $3271.07
JUST FOR THE SCREEN!!!
They are taking the right royal pi$$ with that.
      04-17-2013, 02:05 PM   #15
Ellmat
Ellmat's Avatar
Drives: E70 3.0D MSport
Thanks, Joseph
In the past, there has been a discussion that somebody had purchased a screen protector and from memory this had solved a lot of the problems of light scratches, plus it also gave future protection...i think the screen protector was made by 3M (maybe via eBay..?), but i can't be 100% sure.
Hope this helps a little..?
      08-02-2013, 01:42 AM   #16
BM MAD
Drives: 2011 F10 530d
Unhappy info screen idiosyncrasies??
Roughly 18 months ago, noticed ''darkening spots/smudges'' on screen. Service agent tried various methods to ''clean'' screen. NO success. Local BMW distributors - on my insistence !!! had car for a week to have technical division do intensive testing. RESULT:''user abuse/micro!!!!! scratches''
Obviously I was furious (i.e.: always cleaned dust etc from screen with micro-fibre cloth etc) At own cost requested internationally known expert- a Professor @ local U in ''photonics etc'' to do testing. He issued 3(three) reports debunking the above finding by tech division. NO JOY from agents , had to replace screen @ own cost (prof's final report stated that NO scratches but protective film separated, causing dark spot- he removed protective film with solvent AND PROBLEM SOLVED!! Of course -no protective film then and damage will occur)Therefore had to replace COMPLETE SCREEN -bl--dy expensive. He actually made a remark in final report that he questioned why BMW does not offer a more cost effective solution (i.e.: replacing film) I have now resorted to legal action to recover cost but BMW IS NEGATING ALL ENTREATIES, TREATING MYSELF AND EXPERT WITH DISDAIN AND INSULT. Having been a BMW owner for 30+years- from 3 series to lately all iterations of 5 series plus ALL M5 models - this is disgusting and pathetic. PROBABLY my 2012 F10 will be my last BMW ever.:si gh:
      08-06-2013, 10:56 PM   #17
lmaleke
Hong Kong
13
Drives: shifting priorities for now...
Lightbulb
@NYCE90DRIVER: http://solutions.3m.com/wps/portal/3...Shop_Products/
You have to cut it to fit though...
      09-12-2013, 04:09 AM   #18
dwjpaypal
Drives: G05
I'm also having issues with my iDrive, although I feel my issue is slightly worse than yours...
My iDrive has cracked from about a third of the way on the top to the right hand side!!
I really don't know what to do- 2011 MSport with the pro navigation, do you think this will be a dealer warranty item??
Dave
      09-12-2013, 06:03 AM   #19
Technic
Technic's Avatar
2281
Drives: 2021 i3S, 2024 i4 M50
That would be my answer as well. These are not touchcreens.
And for dust I use a fine duster that does not scratch:
      09-25-2013, 02:22 PM   #20
Daans
Daans's Avatar
Netherlands
51
Drives: Bmw 440ix grand coupe
Scratch
Hi, i'm from the Netherlands.I had the same problem with my BMW f11....i went to the dealer, i got a new one( warranty ) they told me i was not the first one.... So good deal!
If you don't get a new one you can clean it with a glasscleaner... It looks ok, only when the sun is shining it is harder to read.
Hope your dealer will change it!
Good luck!
Daniƫl
      08-12-2017, 12:47 PM   #21
dangom808
dangom808's Avatar
Drives: 2015 F10 528 M-Sport
Bad link. See this one: http://www.3m.com/3M/en_US/company-u...94857497&rt=r3
      11-12-2017, 08:41 PM   #22
pika1460
pika1460's Avatar
17
Drives: e92
i tackled the problem today by simply taking it off and polishing it. The vent cover comes off and you disconnect the 3 plugs from it. after that the screen is held in by 2 torx screws at the bottom. once off pull the lower part forward and it will come out. disconnect the purple plug and take the screen inside inside. there are 3 small torx screws on the back that will allow you to take the plastic shrowd off. after that the thin metal cover on the sides comes off with a little finesse. at this point just dab a microfiber cloth in some very fine rubbing compound and gently start to polish the screen. I did it all by hand and then used a drill attachment for the final stage. in the end you should be able to remove that stupid anti glare coating and everything will look brand new. I will test drive it for a few days and see if it really is a must... i found an ebay seller that provides an antiglare film cut to the exact size of the NAV screen, but honestly i don't see the use at this point.
