2010 2011 BMW 5 Series Forum F10 F11 Rear Speaker Install Plug n Play under £40 |
01-07-2016, 11:24 AM | #1 |
The Flasher
55
Rep 164
As everyone will probably agree the standard sound system in most bmw's is pretty awful, i did a complete amplified install on my e90 3 series so felt pretty confident in tackling the 5.
Now unfortunately this thread is only for the rear roof lining speakers and will only apply to f11's as the f10 setup is slightly different but principle is the same and plug and play connectors will be the same. I started by researching shallow mount 4" coaxial and decided to go for these for various reasons. i also ordered the plug n play speaker plugs and wire from bmw dealer, part numbers.. plug housing-61138373583 wire-61130005198 These only took a day to come into stock. I was then ready once the coaxials had arrived to install, i started by taking the rear speaker covers of these come off extremely easy just use a flat head srewdriver carefully! once off theres just two torx bolts cant remember sizes sorry, once these are out a slight tug down and oem speaker and mount will come free. Then i unplugged and took oem speakers out by unscrewing the 3 torx bolts, prepped new speakers by cutting the top taps of with wire cutters to allow me to fit them in oem mounts. here is the difference between oem and my new in-phase.. Next was to heatshrink and connect the plug n play harness together positive to positive !!! bmw positive is the red line cable brown is neutral, and connect to corresponding speaker terminals. Finally reverse removal and fit back in place, please be assured the oem speaker cover will go back over the coaxial just!! literally a perfect fit. overall the rear sound fill has improved substantially and will be even more noticable once the fronts are done-working progress at present will update shortly. And for less than £40 all in you cant really go wrong just need a bit of confidence and basic knowledge. |
01-07-2016, 02:14 PM | #3 | |
The Flasher
55
Rep 164
I was originally going to do a sub £150 install consisting of plug and play front components and all oem hardware needed, plus rear coaxials, no amp as yet and no underseat upgrade but if i was to do that it would have to be a 4channel amp and sws earthquakes and just run the rears off headunit but maybe in the future. I basically would have gone for these, great price and great performance for the money.. However two days ago managed to get a steal on a focal component set off fleabay so ill wait till there fitted before i pass judgement. Hopefully get fronts done this saturday, and will post experience.
BMW F11 520d M-Sport, Stage2 Remap, Sophisto Grau, Oyster leather, Pro Nav, 20" M5 reps, H&R Sport Springs, Vorsteiner Rep Front&Rear Carbon valance, Quad exhaust Conversion, M5 Grill, Focal Audio |
01-08-2016, 12:40 PM | #5 | |
The Flasher
55
Rep 164
Think your only option maybe to fit a shallow depth component set in there, but its definately going to be trial and error, best of luck. Hey im hopefully mounting focals in the door tommorow though will keep you posted on that
01-08-2016, 01:00 PM | #6 | |
Rep 2,071
04-23-2017, 10:49 AM | #7 |
Rep 3
Hello,
can you suggest an upgrade speakers for front doors? I am not really sure if there s a depth issue or magnet diameter.... would these fit? http://www.upcar.ro/boxe-auto-coaxia...are-10166.html Thanks! |
04-25-2017, 07:21 AM | #8 |
Rep 3
copy / paste
Hello all,
just done the upgrade. same speakers, same procedure. much better bass and treble. The tweeters are almost touching the plastic grill, but don`t think that should be a problem. Thanks for the diy! |
04-25-2017, 07:48 AM | #9 |
Rep 3
alternative to in phase stx 1035
06-11-2018, 11:09 AM | #10 | |
Rep 17
Which tweeters did you end up going with? Thanks |
