05-02-2017, 03:11 AM | #1 |
Rep 47
NRF Issue?
Hi all,
My neighbour recently fitted non run flats to his '14 520d M Sport and has been experiencing regular low pressure warnings despite inflating the tyres to the specified pressure. He has also told me that he is getting traction control warnings on the dash that cause the car to lose power (under gentle acceleration). I haven't seen the car for myself yet, but has anyone experienced anything similar? The issue only began when he fitted the NRFs to the front recently. Regards, Dave |
05-02-2017, 03:37 AM | #2 |
Rep 565
2014 = post-LCI = should be proper RDC pressure sensors in each wheel.
Has he really just put non-RFT tyres on the same rims, or has he got a new set of rims with non-RFT tyres already mounted ? There is no way for the car to tell whether tyres are RFT or not. The tyres themselves are completely "dumb", no RFID tag or other electronic signature. So either he changed to rims with no, or the wrong, sensors fitted, or one or more sensors got damaged by the fitters or one or more tyres isn't sitting flush on the rim. 3 years is too soon for the battery in a sensor to give up I think. What does idrive say about the individual tyre pressures ? How does this compare with a manual reading of the pressures ? |
05-02-2017, 04:13 AM | #4 | |
Rep 47
Thanks, Dave |
05-02-2017, 04:13 AM | #5 |
Rep 47
05-02-2017, 12:55 PM | #6 |
Rep 619
So if the rears were ok, then it could potentially be a front sensor issue?
2017 F10 535d MSport Auto - Mineral Grey - Oyster leather - 19" 351M's - Pro Media - Enhanced bluetooth - MSport rear spoiler - Sun protection glass - Harman Kardon Hifi - Multi Function Display - Ambient Lighting - Folding mirrors - Sunroof - LED adaptive headlights
05-03-2017, 03:21 AM | #9 |
Rep 47
Gents,
The same thought struck me last night. He was out all evening yesterday so I haven't seen the car yet. I'll check it out later. I'll also check the pressures using my own tyre gauge as it has only been checked on a garage forecourt, and how many times has that been dropped?? I once ended up nearly 10 PSI over inflated when I trusted one of those. Regards, Dave |
05-03-2017, 02:07 PM | #10 |
Rep 47
Hi all, I finally got to see the car for myself this evening. Driving it gently the car kangaroos and a message comes up on the left of the dash about a stability issue and to drive cautiously (or something to that effect) along with the odd flash of the MIL. When I stopped and checked the tyres the aspect ratios are different;
Rear: 275/40 R18 Front: 245/45 R18 I assume this is incorrect? I never checked the nearside to see if they matched. Inflating the tyres apparently cures the problem temorarily. It showed no tyre pressure warnings. The car does not have tyre pressure sensors and was built Jan 2014. I assume the tyre fitted fitted the wrong tyres? Edit; having worked it out this looks correct. Any other thoughts? Thanks, Dave Last edited by dmcsweeney; 05-03-2017 at 03:24 PM.. |
05-04-2017, 05:06 AM | #11 |
Rep 47
The problem has now developed further. I've just had a call to say the car cut out while shifting from reverse to drive and is refusing to start!
Regards, Dave |
05-04-2017, 06:35 AM | #12 |
Rep 8,081
Tyre sizes definitely correct - aspect ratios are different because the widths are different.
Ian
05-04-2017, 09:07 AM | #13 | |
Rep 47
Regards, Dave |
05-04-2017, 02:51 PM | #14 |
Rep 47
Hi all,
Yet another update. I took another look this evening and the engine fired up first go.I drove it a few feet and it stalled. It re started up stalled again shortly after. I fired it up and checked the voltage at the jump start point, all good. The engine revs rose twice and dropped as I watched it idle. I then shut it down, re started, and switched off the traction control. On the first test drive I thought it drop back a little once. Next drive (4 miles) all seemed fine with no warnings. I could find my code reader (though I doubt it would tell me much). The JLR software (mongoose) is widely available but I'm new to BMW, is the software or a decent diagnostics tool available? Thanks, Dave |
05-05-2017, 03:29 AM | #15 |
Rep 8,081
Sounds like an ABS Sensor.
Ian
05-05-2017, 04:31 AM | #17 |
Rep 8,081
It will but the software is available on line. Can't be far outside warranty though so a dealer might do a goodwill.
Ian
05-05-2017, 05:46 AM | #18 | |
Rep 47
Thanks, Dave |
05-06-2017, 07:36 AM | #19 |
Rep 581
Not neccesarily - only cars built after March 14 have the individual sensors in each wheel as standard, so there could be a few 14 plates kicking about without them.
Current: 2021 M340i xDrive, 2001 530i Sport
Previous: 2015 530d M Sport, 2010 530d SE, 2008 335i M Sport |
05-07-2017, 04:13 PM | #20 |
Rep 47
