05-09-2015, 09:21 AM | #1 |
Rep 582
Is alpine white 300 paint hard to match? Had a bumper sprayed and the painter said this was the best match. Also he said bumper materials painted will always be slightly different color and shade than rest of car. I personally think the shade can be matched closer and I hate to pay for paint that isn't in my opinion at least 95% match.
05-09-2015, 09:34 AM | #2 |
Rep 1,597
That's way out! I have had two smart repairs both on my front and rear bumpers done by BMW on my AW F10. Both are a perfect match and you can not see any difference at all
05-09-2015, 09:36 AM | #3 |
Rep 474
Damn...that is kinda really off to me. My painted bumper match better. And usually to see if paint match or not, you compare under the sun because usually under low light it's hard to see. But yours even shows 2 different paint shades in low light
05-09-2015, 09:40 AM | #5 |
Rep 474
Here is my thread to review after market bumper. I have a bit fitment issue, but not paint match
http://f10.5post.com/forums/showthread.php?t=1114325 |
05-09-2015, 11:07 AM | #6 | |
Rep 862
05-09-2015, 12:00 PM | #7 |
Rep 582
Yea I agree with all comments. It's really off and I've wasted so much time with these guys. Bad part is this is the outcome of second time it's been painted. First time it was white but very yellow color. Now this is the final result and best match they said. I'm still not satisfied and the shop said no more repaint or refund. Going to see if I can dispute the charge and take it to another shop to paint it.
05-09-2015, 12:20 PM | #8 |
Rep 1,597
As I understand it each paint colour has 6 shade variations to allow for matching and any slight variations, at least that's what I've been told. Many body shops take a punt on the base code rather than spraying out 6 sample sheets and going for the one that blends best.
I'm no paint expert but this is what I was told when I had a match issue on my wife's A Class and had to have the bumper repainted after the initial repair was way out... |
05-09-2015, 12:46 PM | #9 |
Rep 14,522
That's way off. I know sometimes u can't match it exactly but that's like two different whites. I'd recommend taking it somewhere else or else ur gonna have people looking at car and ur gonna know why. I've had all my other cars taken into a body shops and they've manage to color match the car every single time. Just Sounds like that shop doesn't have all the abilities to do what a paint shop should?
05-09-2015, 05:03 PM | #10 | |
Rep 10,185
BASF Glasurit is the official BMW refinish paint and Standox is the supplier of the factory paint (Spies Hecker is the same as Standox aswell, same company different tin). They develop their mixes directly with BMW so the match will be very good with a proper colormatcher. See if any place near you uses these or other top brands
BMW if you are reading, I need a job, Please. |
05-09-2015, 05:11 PM | #11 | |
Rep 10,185
Did lots of work for a company that as one of their jobs trains colormatchers. They would mix the base color spec , spray it on a test card and then slightly adjust the color as needed by adding certain small amounts of color or metallic flake mix, using very sensitive scales to ensure they are adding the correct amounts. Decent color matchers could match any color perfectly in less than 15min with only a few test card sprays. The instructors could often judge by eye and get the mix right before even spraying 1 test card (same guys would do work for the 3 Series factory in Rosslyn from time to time)
05-09-2015, 05:17 PM | #12 | |
Rep 10,185
All refinish paint (non factory paint) is mixed from a set of base colors and metallic/pear/xirallic flakes according to formulas developed by each paint manufacturer and matched to each car. Paint also slowly changes color with car age and UV expsure. Even the factory paint is mixed and adjusted per batch. Plastic parts also have a plasticizer added to the paint that slightly changes its mix and is cured differently to metal parts. Factory paint cannot be used to repair cars since it requires large very hot ovens to cure and these would melt plastic and interior parts.
05-09-2015, 05:57 PM | #13 | |
Rep 862
05-09-2015, 06:07 PM | #14 | |
Rep 14,522
I just can't believe a shop would actually let u drive off knowing it Looks that bad! We're they hoping u said it's OKAY? |
05-09-2015, 08:56 PM | #15 |
Rep 11,136
My father used to have a BMW motorbike. They had to respray the tank twice before the match was right. Same with my brother's metallic gray M3. Rear bumper off, but second time around it was perfect.
05-09-2015, 10:31 PM | #16 |
Rep 474
I agree that the shop suppose to spray a few times before the color comes out right. In fact, I heard of that before too. But that "few times" suppose to be done before they return the car to customer. What kinda of shop that return something like that and called it done. That's really bad business.
05-10-2015, 12:15 PM | #17 |
Rep 937
That isn't close and you should demand the shop to either refund your payment or fix the problem. Hopefully you paid with a credit card. If the shop isn't cooperating, call your credit card company and dispute the charges.
05-10-2015, 08:06 PM | #19 |
Rep 1,158
Lol...hate to say it man, buy your painter SUCK ASS! I had my front bumper painted and it match 100% alpine white.
BMW f10 550i Msport
05-10-2015, 09:01 PM | #20 |
Rep 14,522
05-10-2015, 09:56 PM | #21 | |
Rep 582
05-10-2015, 09:57 PM | #22 | |
Rep 582
