2010 2011 BMW 5 Series Forum F10 500 miles left on extended warranty |
06-30-2016, 09:36 AM | #1 |
Rep 428
Should I bring my car in before warranty runs out?
No major problems just a little engine or tranny lag. Let me know your thoughts. My car is a gold level. |
06-30-2016, 10:24 AM | #2 |
Rep 878
What's gold level? If nothing's wrong with it that you can tell, what are you expecting the dealer do with it when you drop it off? Only thing I can think of is to have them ensure the firmware is up-to-date, check for any hidden fault codes or inspect the car for leaks/unusual wear that could afford repair.
-WJV
06-30-2016, 12:22 PM | #3 |
Rep 1,472
Agree, no reason to bring it in unless you suspect something's wrong, nothing for them to do. Any other check you might request you're likely to be asked to pay for their time.
07-11-2016, 11:19 AM | #4 | |
Rep 428
they had to rule out plugs at $650 first. they also said it may because my wheels being bent that it caused the transfer case problem. i had the customer care recall last year and they replaced the plugs as part of that. i shouldn't need new plugs. transfer case is around $4500, but under warranty. any thoughts? |
07-11-2016, 12:39 PM | #5 | |
Rep 1,472
I'm not sure what to tell you honestly. Maybe someone who knows more, and works on his own car can help out with advice, but I would think symptoms of transfer case would at least be some sort of noise. Not certain bent wheel explanation makes sense or how spark plugs misfiring would be mistaken for transfer case failure? If the same dealership replaced the spark plugs a year ago, I would think that they should assume some responsibility for that? |
07-11-2016, 02:58 PM | #6 | |
Rep 878
-WJV
07-11-2016, 08:38 PM | #7 |
USAF Pararescue Veteran
332
Rep 770
If you have maintenance with your warranty them have them do things like the belts, wipers, oil change (if mileage allows), basically anything that falls under the maintenance.
$650 for to "rule out the plugs" is ridiculous, especially if they were just changed last year. Bent wheels won't cause a transfer case to fail, you would have to riding on basically square wheels for that to happen and they wouldn't be holding air at that point. I would call BS with my SA on both of those issues. |
07-12-2016, 08:02 AM | #8 | |
Rep 428
