07-03-2016, 03:46 AM | #1 |
Rep 1,607
Drives: 2020 M8 Comp First Edition
I just wanna clarify that is Avg ign range of 0.2-0.5 is ok with running 7.75 gals of e85 n rest 93.
Mods: Run map5 Jb4 + E85 harness BMS intake Sprint Booster 59k on the car and been like this about a year no codes or any issues just general knowledge question. Thx GT
GT
2020 BMW M8 Comp First Edition 2019 Panamera Turbo 2021 BMW X6M Comp 2019 BMW M5 2018 Maserati Ghibli SQ4 GranSport |
07-04-2016, 12:53 PM | #2 |
1505
Rep 676
Drives: '17 F31 340xi US Spec
That is normal ignition for idle condition and you should not worry about it. What is your ignition at WOT?
07-04-2016, 03:31 PM | #3 | |
Rep 1,607
GT
07-05-2016, 04:08 PM | #4 |
IG @bmwF9xG80
3812
Rep 7,593
Under 3 for E85 usage is good and you're under that so even better.
Did you test your ethanol content before pouring ? Here's a logging parameters and their meaning http://www.n54tech.com/forums/showthread.php?t=21269 Avg Ign: Average Ignition Retard. A JB4 calculated value with a range of 0 - 6 that represents the average amount of timing below the maximum possible curve over a short term window. Lower values indicate a higher overall ignition advance while higher values indicate a lower overall ignition curve. This calculation is used by the JB4 for evaluating octane content by both map 5 (auto learning) and map 3 (methanol injection). Values below about 1.5 result in full Map 3 or Map 5 scheduled boost levels. Values between about 1.5 and 6.0 result in lower and lower boost targets as an added safety feature for these two maps. As a general rule when using meth, race gas, or heavy E85 mixtures look for values below 2.0. When using pump gas expect values of 5 or higher.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
petersk21.50 |
07-05-2016, 08:44 PM | #5 | |
Rep 1,607
GT
07-06-2016, 09:36 AM | #6 |
IG @bmwF9xG80
3812
Rep 7,593
http://www.ebay.com/itm/251447717425...&sojTags=bu=bu
Friend of mine tested 1 station he use to go to and it was only E70 content, you cannot waste your time with less than E80 content.
07-08-2016, 12:27 AM | #7 |
IG @bmwF9xG80
3812
Rep 7,593
Also whats your FP_H under WOT?
If 11 or under you have too much e85 that your HPFP can handle
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 Last edited by FSociety; 07-08-2016 at 12:18 PM.. |
07-08-2016, 04:03 AM | #8 | |
Rep 1,607
GT
07-08-2016, 12:18 PM | #9 |
IG @bmwF9xG80
3812
Rep 7,593
You can also get some more direct views on the n54tech.com forums from more JB4 experts
07-08-2016, 04:51 PM | #10 | ||
Rep 1,607
100F outside lol
GT
FSociety3811.50 |
07-11-2016, 08:00 AM | #11 |
IG @bmwF9xG80
3812
Rep 7,593
Thats really good lol, only map5 ?
have you tried on map1 or 2 too ? Do you have EWG wires ? or just the FF/E85 wires connected I only had 4 gallons of Pure E85 + 12 gallons of 93 on map1 my avg_ign was .5 and map2 .9-1.2 range which is still awesome. (20-21 psi) since my runs 13 psi stock
07-11-2016, 03:29 PM | #12 | |
Rep 1,607
GT
07-13-2016, 10:17 PM | #13 | |
IG @bmwF9xG80
3812
Rep 7,593
Would be awesome to see how it does on your different maps versus delta (map4) PM me your Map6 configs if you dont mind
08-25-2016, 09:57 AM | #14 | ||
Rep 1,607
Pics
GT
FSociety3811.50 |
08-25-2016, 01:04 PM | #15 |
IG @bmwF9xG80
3812
Rep 7,593
Thanks GTATX who configured map6 for you ? have you posted your logs / settings on n54tech or sent to Terry curious ?
FF/Wasteadaption is so high never seen that before
08-25-2016, 04:51 PM | #16 | |
Rep 1,607
GT
08-25-2016, 04:57 PM | #17 | |
Rep 1,607
GT
08-28-2016, 01:11 PM | #18 | |
IG @bmwF9xG80
3812
Rep 7,593
Have you posted on N54tech ?
11-22-2016, 12:06 PM | #19 |
Rep 1,607
Haven't done logs been running fine but will post logs when get a chance.
GT
11-22-2016, 06:28 PM | #20 |
IG @bmwF9xG80
3812
Rep 7,593
Your FF/Wastegate Adaptation is really high, send a log to Terry@burgertuning.com or post it on the forum i remember seeing someone lately and 150 is bad. Being so close to 150 I would try putting it back to 60 and see if it re-learns.
