2010 2011 BMW 5 Series Forum F10 Upgrade/Larger HardDrive ? |
02-05-2012, 04:37 PM | #2 |
Rep 94
02-06-2012, 11:34 AM | #3 |
Rep 10,185
Its a 2,5" 80GB TOSHIBA PATA Automotive spec hard drive (MK8050GA)
About 65GB goes to the Nav unit, the rest to Gracenote ( entertainment software), System, Speech, Contacts and user Music uploads
BMW if you are reading, I need a job, Please. |
02-07-2012, 07:00 AM | #4 |
Rep 130
I have a 320GB plugged into the USB in the arm rest
If that helps It has to be a specific USB 2 type
One you lock the target
Two you break the man Three you slowly spread the net And Four you catch the man |
02-07-2012, 07:06 AM | #5 | ||
Rep 10,185
The USB ports are not rated for external hard drives. They are not rated to provide the power required and may burn out. You will see the owners manual warns against it Quote:
02-07-2012, 08:43 AM | #6 | |
Rep 130
If so how will they prove i had a HD connected to it if it burns out?
02-07-2012, 06:48 PM | #7 |
Rep 231
Armrest USB don't supply enough current to charge 3.5" HDDs, which require about 1.4A to spin it up from stop. that's why you see those 2 USB plugs for 3.5" external drives. nothing will burn out if you plug in 3.5" external drive to armrest USB, HDD won't spin up that's all. 2.5" drives don't require as much power and it will work on armrest USB. only problem with using HDD in the car is in the winter and summer, where temperature goes over/under rated temp, and this can cause damage or have performance drop. best bet is use SSD or big USB thumb drive.
