2010 2011 BMW 5 Series Forum F10 Anyone successfully coded F10 in the UK? |
04-10-2015, 10:57 AM | #463 | |
Rep 31
Chirp on locking
I've coded HU_CIC->ACOUSTICAL_LOCK_CONFIRM->aktiv But still no beep on lock / unlock I've checked the following FZD->3001:- Buzzer level high level_7 7 Buzzer frequency initwert 79 Buzzer duration initwert 0A Any ideas as to why it doesn't work? In idrive I've ticked the box that has now appeared "acoustic sig. lock/unlock". It doesn't seem to have any effect. Thanks Last edited by pow216; 04-10-2015 at 11:03 AM.. |
04-11-2015, 03:28 AM | #464 | |
Rep 9,097
Akkustische Quittierung Schaerfen Akkustische Quittierung Schaerfen mit Klappenbeachtung Akkustische Quittierung Entschaerfen to aktiv Revert all other values to default in FZD and CIC which are related to buzzer. Akkustische Quittierung Entschaerfen to activ in FZD module and you will be good to go.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
04-11-2015, 02:01 PM | #465 |
Rep 31
makkan00,
Thanks so much. It is working now. I am trying to get the car to beep on lock only, any ideas? I think Schaerfen means arm and Entschaerfen means disarm. Even with only coding "Akkustische Quittierung Schaerfen mit Klappenbeachtung" to aktiv I get two beeps when unlocking the doors. I will try setting only "Akkustische Quittierung Schaerfen" aktiv later or tomorrow. |
04-11-2015, 02:16 PM | #466 |
Rep 31
With the the following settings I get 1 beep on lock and NO BEEPs on unlock:-
HU_CIC -> 3000 ACOUSTICAL_LOCK_CONFIRM = aktiv But make sure the tick box in idrive is not ticked!!!!!!! then I set:- Akkustische Quittierung Schaerfen = aktiv Akkustische Quittierung Schaerfen mit Klappenbeachtung = nicht aktiv Akkustische Quittierung Entschaerfen = nicht aktiv After a bit more playing around and reading one of shawnsheridans posts the meaning of the settings dawned on me Akkustische Quittierung Schaerfen = Acoustic acknowledgment when Arming regardless of the door status Akkustische Quittierung Schaerfen mit Klappenbeachtung = Acoustic acknowledgment of Arming depends on the door status I think "door status" here means whether the i-drive box is ticked or not. So unticking it manages to turn off the two beeps some of us don't want. But the mystery remains as to why Akkustische Quittierung Entschaerfen = Acoustic acknowledgment when Disarming gives the two beeps even when set to nicht_aktiv !!! So if I tick the i-drive box the two annoying unlock beeps come back. Last edited by pow216; 04-11-2015 at 02:38 PM.. |
04-14-2015, 05:00 PM | #467 |
Rep 94
Can anyone tell me if coding will void warranty? Would BMW be able to detect that the car has been coded?
Also can the internet browser be enabled via coding alone? If so does it then use the car's own sim or your bluetooth for data? |
04-15-2015, 05:11 AM | #468 | |
Rep 1,207
Answers inline...
04-16-2015, 04:03 AM | #469 |
Rep 94
Thanks gspannu. So from what you say even if the coding is reverted back before going to the dealers they can see a change log which would show them that is has changed. Makes coding a bit of a risk I guess if they can see what you have done previously.
04-16-2015, 05:32 AM | #470 | |
Rep 1,207
It is only if the dealer suspects that there has been a software fault, and they go about specifically digging into some logs; and then they they might notice that something has been changed. Whether they can attribute the change to you and make a warranty claim void is a debate. - Can BMW (from a technical capability perspective) find out whether you have coded your car or not? The answer is YES. - Does a dealer check that a car has been coded? The answer is NO. - Will a dealer check that you have coded your car if there is a software issue. The answer is usually NO. - Can a dealer find out if your car has been coded, if he specifically thinks that some misuse has happened. The answer is YES. At the end of the day, it is a risk that you have to be prepared to take vis-à-vis the benefits of the features you get via coding. I have coded cars over a 100 times, and so far no one has ever reported a dealership having an issue. Country wide there would be thousands of coded cars and dealers none the wiser. I never code back any changes before taking my car to the dealership. Have been coding for over 3 years. My own cars have been coded and I continue to do more modifications as and when I find time. At some level it is all irrelevant; its your choice and the appetite for the risk.
04-16-2015, 09:03 AM | #471 |
Rep 492
gspannu, whereabouts are you located?
F10 M5 CP.
Previous: F31 340i, E90 335i SE, E87 130i, F10 550i, E92 335i, E61 550i, E90 335iM, E87 130i, E87 118d, Z4M, Z4 3.0i SMG, E46 330D, Z3M, Z3 3.0i, Z3 3.0i (USDM) |
04-20-2015, 03:36 AM | #474 |
Rep 1,207
Nope... Cannot be coded (as far as I am aware).
04-20-2015, 04:43 AM | #475 |
Rep 565
03-19-2016, 07:48 AM | #477 |
Rep 5,112
whynot give it a go yourself? . just a laptop and a cable and the software ( search these forums...)
I am not as experienced as others here with coding but have made a few changes myself. just follow the instructions very carefully. Huge list of things you can change , most quite minor but some more significant such as disabling stop / start. I have had my car serviced twice since coding and they have not updated the software and my changes are still there. |
03-19-2016, 10:10 AM | #479 |
Rep 295
I would but don't own a laptop only a mac and iPhone. I'm keeping my eyes open for mycarly updates as I used this on my e90 but need there 2nd gen wifi but that could be months away.
03-19-2016, 12:06 PM | #480 | |
Rep 5,112
If I may , one such link here if I'm allowed to post. http://www.motor-talk.de/forum/aktio...hmentId=722804 My favourite setting changes on my car are Disable stop /start and Indicators displayed in the HUD. |
03-20-2016, 08:02 AM | #481 |
Rep 96
PM'd you.
F10 LCI 535d (313PS) M Sport
12-19-2016, 11:30 PM | #482 |
Rep 37
Glad I have found this thread - I have just bought (last month) an F10 M5 and really disappointed with the Ambient Lighting. Have been searching alsorts to see if there is a fix, and this looks to be about the best I'll be able to do without taking off Door Cards and chopping in new LED's etc.
I've never done Coding before, but i'm confident i'll be ok given there are plenty on this thread that are similar and have been successful... Any chance someone could PM me the links to the E-Sys Download? I should be able to sort the cable myself. Looking forward to seeing what little bits I can adjust to make the car more Personal / Comfortable... P.S. I also have a 4.8is E53... does this software work with this too? Would like to set Auto Fold Mirrors, Auto Locking etc.. Turks.
Current:
(2018) F85 X5M - Donnington Grey (2004) E53 X5 4.8is - Sapphire Black Past: (2014) F10 M5 - Monte Carlo Blue |
09-21-2017, 11:20 AM | #483 |
Rep 32
LDW
Hello Gspannu.
Coding is very new to my but after reading forums for hours and hours i got all the software and a Enet cable and managed to code some simple things on my F10 from 2016. Coded blinkers in HUD , High Beam Assist and some other things. Now i have bin reading on coding LDW on my F10, but there i am a little scared read on alot of forums that they get allot of errors after trying to code LDW (like camera errors ,sorry for my English it is not so good i live in Belgium ) Can it be code if you dont have the swith and dont have the vibraiton in the steering wheel without errors?? I ask this because coding is very new to me and if i get errors i would not know how to fix the errors problems. ( I got Ista installed and that works and i know how to let the program read the car for errors and erase the errors but i am not sure that if ik get errors after trying to code LDW that i can erase them with Ista. So i am turning to you and ask if you can help me with this. These are my car options [IMG]D673386_NL optielijst kopie-1 by Antonio Isidoro Pestana, on Flickr[/IMG] [IMG]D673386_NL optielijst kopie-2 by Antonio Isidoro Pestana, on Flickr[/IMG] Hope to hear from you or someone els that has code this option on a F10 LCI Thank you |
09-21-2017, 02:41 PM | #484 | |
Rep 1,207
Not worth the hassle in my opinion. |
