2010 2011 BMW 5 Series Forum F10 Replaced all eight spark plugs |
08-04-2015, 11:11 AM | #23 |
Rep 736
08-04-2015, 12:02 PM | #24 |
Rep 2,416
BOSCH the same ones our cars use from Amazon, so much cheaper than from BMW. by about $100 that's with 20% shop discount.
http://amzn.com/B00RY4J38U
2011 550i RWD 60-130 7.35
08-04-2015, 12:06 PM | #25 |
Rep 249
I left my car with the dealer, and boy I'm not so sure anymore. They say I have a misfire on cylinders 5 and 7 now (which shouldn't be the case), and nothing on cylinder 1 (which had a misfire locked in when I dropped it off). 5 and 7 injectors were already replaced as discussed in my first post, and I'm starting to think I may need to grab a new set of coils after all. Time to do some more shopping.
I hope they're smart enough to pull #1 plug like I suggested, if so, it definitely will give the tell-tale sign that the injector is leaking. Who else has done a coil swap, and is there an upgraded set of coils out there for the N63? I thought I saw something on ECS before, but I can't find it now.
2011 BMW 550 i / Sophisto Grey / BMS Stage 2
08-18-2015, 04:55 PM | #28 |
Rep 42
Drives: 2018 BMW M4 comp -- BMW x5 G05
Where to start
does anyone have any pictures around the removal of the shrouds and the location of the spark plugs.. I have a gist but with the turbo this is a little bit different from my e60..
08-24-2015, 06:22 PM | #29 |
Rep 243
The whole job is simple. I did it yesterday in the street waiting for my girlfriend to get out of the shower. Took 40 minutes.
The turbo's dont even come into play with this. Unplug the MAF and loosen one of the two hose clamps to the box. Pull the hose back and then pry the tab out of the tube below. Release the metal clip by the orange rubber mount and remove the o2 sensor wires from the routing clips. The airbox then comes out with a good yank as an assembly. It's a little tricky to pull the box the first time (because you're worried about breaking something). After you get the hang of it, it can be done in under a minute. |
08-25-2015, 06:34 PM | #30 |
Rep 11
Replcacing and coding injectors
I am having some issues with my N63 engine 550i. Recently, it has started misfiring slightly on cold start and will trip the "drivetrain error" warning. When I read the codes, it is a cyl 5 misfire - injection shut down.
I pulled the spark plugs (dealer was supposed to change ~10k miles ago) but they looked a little worn. What I think is cyl # 5 plug looked normal colour. Am I right in assuming the RHS while looking at the front of the engine is #5 and #1 is front LHS? Interestingly, plug #1 looked more problematic. Was very black. I have changed all the plugs but I don't think it solved the issue. It sounds like an injector issue to me. But is it #5 or #1? If I change injectors, can I just change one? Or do I need to do them all? Do I really need to recode? If so, where can I buy the tool? Thanks in advance |
09-19-2015, 07:02 PM | #31 |
Rep 736
This site has Bosch spark plugs for 100 and genuine bmw spark plugs for 150. Is there any major difference between the two ?
https://www.ecstuning.com/BMW-F10-55...ugs/ES2794923/ |
09-21-2015, 08:34 AM | #32 |
Rep 738
found them a bit cheaper, $87 shipped
http://www.ebay.com/itm/BMW-F01-F02-...21f277&vxp=mtr Already ordered the socket, gonna order this ones on the next paycheck. My car is getting close to 40k miles, and supposed to be done every 30k, and I do drive it fairly hard with the Stage 1. Lets see how they turn out.
2011 550i
2013 M5 2014 M5 CP 2016 550i |
09-21-2015, 08:19 PM | #33 | |
I am groot
25
Rep 149
2011 550i M SPORT
CF kidney grills, rear diffuser, rear spoiler, bmw emblems, Megan Racing mufflers, H&R Sport Springs, Forgestar F14's Front 20x9/275/30r20 Rear 20x11 305/25r20, AQ3500d, Audio Control LC2, custom ascendant audio 12" chaos/mayhem's 4th order |
09-22-2015, 07:44 AM | #34 | |
Rep 738
I didnt change the spark plugs in my G37 until after 100k, and was running perfectly fine.
2011 550i
09-23-2015, 11:46 PM | #35 |
I am groot
25
Rep 149
I get my car back from the dealer tomorrow for HPFP recall, I'm changing the plugs when I get it home. Rock auto has the stock Bosch (BOSCH ZR5TPP33 OE) plugs for $8.88 each or $76.66 for all 8 shipped. This is where I bought mine
2011 550i M SPORT
CF kidney grills, rear diffuser, rear spoiler, bmw emblems, Megan Racing mufflers, H&R Sport Springs, Forgestar F14's Front 20x9/275/30r20 Rear 20x11 305/25r20, AQ3500d, Audio Control LC2, custom ascendant audio 12" chaos/mayhem's 4th order Last edited by Autobuffoonery; 09-24-2015 at 12:02 AM.. |
09-24-2015, 01:02 AM | #36 |
Rep 844
Im due for mine pretty quick as I'm about to hit 60,000 miles, I called NGK and they don't make a plug so I'm just going to do stockers as well. my car runs flawless on the ones it has so I see no reason to upgrade at this point, but I would like to run a heat range cooler for increased boost.
2014 M5 Competition with ESS Tuning Flash
Gone but never forgotten...2015 X5 50i M Sport, 2015 550i M-Sport, 2015 M3, 2014 X5 50i M Sport, 2015 435i M Sport, 2011 550i, 2011 535i |
09-24-2015, 02:39 AM | #37 | |
I am groot
25
Rep 149
2011 550i M SPORT
09-24-2015, 07:41 AM | #38 |
Rep 738
not really, you need a thin wall socket
2011 550i
09-24-2015, 09:16 AM | #40 |
Rep 738
As long as its 3/8" 14mm thin wall you good
2011 550i
09-24-2015, 03:26 PM | #42 |
I am groot
25
Rep 149
I'm changing my plugs to hopefully get rid of a slight rough idle and when I say rough I mean it's barely noticeable. I picked my car up from the dealer today, for the fuel pump recall and it feels the same as it did before I took it in. My plugs won't be here till Monday, a shipping error on thier part. So I won't be able to say if it helped my issue, but it needs them anyway based on mileage.
2011 550i M SPORT
09-24-2015, 03:52 PM | #43 | |
Rep 736
I'm looking to get mine swapped out as well. How hard is the install? Is it like changing spark plugs on any other car or is there some computer programming that bmw dealer has to do ? |
09-25-2015, 11:27 AM | #44 | |
I am groot
25
Rep 149
2011 550i M SPORT
