2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Strange noise coming from engine (N55) 535i LCI
      02-16-2024, 08:04 PM   #1
F10Abbas
Drives: BMW 535i
Hello guys I noticed that there’s a strange noise coming near the firewall of the engine bay right where my fuel rail is. I had the valve cover replaced in 2/23. I know there is an oil leak and have the gasket on order to replace but could it possibly be related or is this normal? The noise was consistent until I turned the ac on and off then it started with the rhythm heard in the video. I turned the vehicle off and on again and the noise went away. Attached in the link is a video of the noise. https://youtube.com/shorts/ahG4WO2UmQ4?feature=shared
      02-16-2024, 09:59 PM   #2
ChiltiCoatl89
ChiltiCoatl89's Avatar
Drives: 2016 F10 BMW 535i M Sport
A very strange noise indeed!
      02-16-2024, 10:13 PM   #3
Conserve
Drives: 1976 BMW 2002 & 2015 BMW535i
1). Remove cover on R.H. side (above blower motor) and try the bower motor with ac on and off see if it is from blower motor.
2). See if noise/sound change when oil fill cap removed
      02-17-2024, 08:44 AM   #4
F10Abbas
Drives: BMW 535i
I will try these both later today, it’s very strange because it will still make the noise even if the ac is completely off.
      02-17-2024, 01:55 PM   #5
GrabacrOne
GrabacrOne's Avatar
178
Drives: F10 535i
It sounds like the diaphragm inside the pressure converter/boost solenoid (part no. 11747649407). I had 2 of mine fail and it would make this noise if I had gotten into the boost hard. A small blip of the throttle would make the noise stop. LCI 535i models up until a build date of 07/2014 have a PWG. EWG N55s don't have this boost solenoid.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #578262 as a referral.
F10 535i M-Sport | Gone but not forgotten: G01 X3 xDrive30i M-Sport; F15 X5 xDrive35i; E70 X5 4.8i
      02-18-2024, 04:17 PM   #6
Surly73
^^^ This 99%. I've been through four. Relatively inexpensive. Relatively easy to replace (a bit of a PITA fighting with 10mm sockets and stuff but what you're trying to do is easy.)
      02-18-2024, 07:25 PM   #7
F10Abbas
Drives: BMW 535i
Thank you guys. I believe this is the answer as I have pinned the noise right to the solenoid so I will be replacing it alongside with my valve cover gasket.
