2010 2011 BMW 5 Series Forum F10 F10 '13 528i Major Headlamp Condensation/fog |
01-24-2024, 02:22 PM | #1 |
Rep 16
Drives: 2013 BMW 528i
Hello,
I recently noticed about 3 weeks ago condensation and fog in my passenger side headlight. Some quick contextual facts: - Bought car Sep. 2022 from DTX - Live in Northwest Arkansas - This current winter is its second here - This winter has been especially rough in terms of temp and humidity (went to negatives first time in years) and winter seasons are usually dry, but this season and especially the past month or so it has been constantly raining - Yesterday got the Headlamp/parking malf. And the passenger side DRLs are off. - Malf. Goes away after turning on and off car, and the DRLs stay on, even after I drive near an hour, although this morning it came on after about 20ish min of driving - Tried the manual’s guidance w/ keeping lights on but didn’t work. Is there any chance I could fix this myself? As you can see in the pictures, I opened up the vent and found some water droplets down on the bottom, right above that blue wire you can see it ever so slightly (used q-tips to dry it up), but I have no clue where that came from… it looks pretty darn clean inside. I have seen people throw cardboard over the hole and use a blow dryer in the vicinity to dry it up. Not sure if I should do that though. I also attached images of the cover, as I have no clue if there’s a sealant on it or not. Any help is appreciated, and let me know if any other info is needed to better help. I really don’t want to take it to the dealer, I’m a BROKE college student |
01-24-2024, 05:36 PM | #2 |
Rep 21
Tons of info about this occurrence. Seems like every F10 is effected. Conduct some google searches and you’ll see. It will be difficult to fix it yourself, but I have no idea what you are capable of mechanically.
I have 2 F10s and both needed repairs. The longer you wait to get repaired, the more damage the moisture will do and the more the repair will cost. I had mine fixed at a shop near Philedelphia called Philly Pure Customs and they did an amazing job at a very reasonable cost. I realize you are no where close to them, but if you look them up on Instagram, you will get an idea what’s involved in the repair. https://www.instagram.com/philly_pur...l4MGFzdzJrd211 |
01-24-2024, 08:55 PM | #3 |
Rep 2,995
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
Hey Gabe, I was having a lot of condensation, and noticed that the top weatherstrip seal was literally falling apart. I replaced both sides, and that fixed my problem. YMMV of course, but it's a cheap fix compared to resealing the light. Headlights have to come out, but that was pretty straightforward.
https://www.fcpeuro.com/products/bmw...ht-63117240368 |
ctcarbonari292.00 ChiltiCoatl891769.00 |
01-30-2024, 10:23 AM | #4 | |
Rep 16
StradaRedlands4940.50 |
01-30-2024, 11:02 AM | #5 | |
Rep 2,995
Gabe5.50 |
02-09-2024, 08:24 PM | #6 | |
Rep 16
P.S. this was a private mechanic, NOT a BMW dealership. |
02-09-2024, 09:00 PM | #7 |
Rep 435
Drives: 2016 F10 BMW 535i M Sport
Eventually it will affect the electrical, if not taken care of As soon as you can, you can use desiccant and the hair dryer methods, however, only band-aids to a complete Suture. you can definitely reseal it!
02-10-2024, 01:02 PM | #8 | |
Rep 16
Thanks for the response, very helpful. |
02-10-2024, 01:32 PM | #9 |
Rep 14
If I can help you, I did it like this: opened the headlight cover and dried the headlight from the outside. I dried everything in 45 minutes. Use the days when there is plenty of sun to help you in the drying process. Now I watch where the moisture will appear first. That way I will be closer to the heart of the problem
02-10-2024, 02:02 PM | #10 |
Rep 1,873
If I were setting out on a path to fix headlight condensation (and I might be soon) I would be taking a serious look at this guy's work:
https://www.youtube.com/watch?v=-ErJ6iC3Ip4 IMO the gasket referenced should be in good shape, but does not seal the headlight housing and make it watertight. It should be watertight (except the vents) on its own. |
Gabe5.50 |
02-10-2024, 03:27 PM | #11 |
Rep 139
I pulled my headlight today and looked for cracks. I could not find any so I replaced the gasket and both caps. Keeping my fingers crossed for the next rain!
02-10-2024, 05:39 PM | #12 |
Rep 72
Drives: 2015 BMW 535i xDrive M sport
I had the same issue on my driver's side and bought new lenses on amazon. It's a pain cutting the old lenses but it fixed my condensation problems. I didn't need to do the passenger side but did it anyway to renew the look.
StradaRedlands4940.50 ChiltiCoatl891769.00 |
02-10-2024, 06:48 PM | #13 |
Rep 2,995
There are some services on ebay and probably elsewhere that specialize in this. Probably money well-spent. Look pretty legit based on the feedback:
https://www.ebay.com/itm/233681120296 https://www.ebay.com/itm/124814454556 |
Gabe5.50 |
02-10-2024, 07:42 PM | #14 |
Rep 435
Yeah, That service I have seen before Colonel, and it seems promising and at a good price too!
02-10-2024, 10:51 PM | #15 |
Rep 16
So generally, where is the sealant relative to the pictures I’ve shown? And if I use desiccant, would I just drop a few packets in that electrical area, wait maybe 24 hrs on a sunny day, and see if that clears it up?
I may enlist the help of a friend to fully take off the headlight and send it off, but before doing that I’d like to at least clear it up, “band-aid” it. Would using a blow-dryer directly in that unit I opened up from the hood be safe? Again, thank you everyone for the help and directions, I apologize if I continue to ask redundant questions. |
02-10-2024, 10:53 PM | #16 | |
Rep 16
02-10-2024, 11:15 PM | #17 | |
Rep 16
02-11-2024, 12:07 AM | #18 | |
Rep 2,995
I believe in you! |
Gabe5.50 |
02-11-2024, 12:21 AM | #19 |
Rep 829
Another option is to rebuild both of your head light assemblies for a total of $385.64 (or an average of $192.82 each side):
Note 1: Prices and links above are for F10 LCI headlight assemblies. eBay sells similar parts for F10 pre-LCI headlights for similar price points. Note 2: You'll need to transfer your original headlight innards over to the new housings, and external covers/electronics Note 3: You'll also need a roll of Butyl headlight sealant (7mm x 6 meters should suffice) Why this option? The black housing breaks really easily around the area where it mates with the lens, which is very, very hard to remove without incurring "some" damage to the housing. This solution allows you to easily break away the housing material, transfer the interior over to the new housing, and button your headlight assembly rather easily and quickly, with great results. Last edited by M_Bimmer; 02-11-2024 at 11:09 PM.. |
StradaRedlands4940.50 s_ribs37.50 |
02-11-2024, 01:27 PM | #20 |
Rep 1,873
02-11-2024, 11:13 PM | #22 | |
Rep 829
You don't need high PSI to make bubbles in a water/dish liquid mix...and all of the access holes are sealed. |
