2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum 2011 535xi GT N55 - ISTA 1C3102 oil pressure sensor too low before engine start
      01-28-2024, 10:50 PM   #1
iverson03tj
Drives: e39 M5, F07 535gt xD
Hey yall. I could really use your help with troubleshooting this one. Just bought this car with 174k km and fixed a few things listed below.
Got this code on ISTA. 1C3102 - Engine-oil pressure sensor, plausbility : Pressure too low before engine start
- Replaced the Oil Pressure sensor
- Replaced, ignition coils, spark plugs, oil filter & cooler housing gasket, belt tensioner and both pulleys.
- changed the oil filter cap to a URO metal one with a metal inner filter. (I heard that this can cause the oil pressure code, so will try to change it back to the plastic oil filter cap tomorrow)
- reset adaptation ran well but a slight hesitation
- I did the priming procedure and coolant purge procedure
Details:
Oil temp 102c - 105c
Oil pressure at Idle = 1600 hPa / 1.6 Bars / 23 psi
oil pressure during driving = is 4k hPa @ 1600 RPM to around 7k hPa @6k RPM
      01-29-2024, 09:41 AM   #2
iverson03tj
On another note:
the Previous owner somehow stripped the oil pan drain plug -_-
So i am installing a Helicoil to it.
RealOEM.com It shows the drain plug as M12x16
Does the 16 stand for 16mm and does it mean its 16mm in height of the entire bolt or just the thread?
I googled it and it says that the drain plug is M12 x1.5 thread
      01-29-2024, 10:10 AM   #3
iverson03tj
Ref: oil filter cap to a URO metal one with a metal inner filter.
This is the one i used
https://www.ecstuning.com/b-uro-prem...27525334prm~u/
      01-29-2024, 05:32 PM   #4
Conserve
Drives: 1976 BMW 2002 & 2015 BMW535i
1). 16mm is length of threads. full specs Oil Drain Plug With (12 X 1.5 X 16 mm)
2). Throw that URO oil filter cap with a metal inner filter in neighbor's pool and go back to original. You and your engine will be lot happier.
      02-17-2024, 09:00 AM   #5
iverson03tj
Thank you for the suggestion, I swapped the oil filter cap back to stock, still the same issue exists.
      02-17-2024, 10:22 AM   #6
Conserve
In OP you said changed oil filter cap & metal inner filter. Last post swapped the oil filter cap back to stock. If I follow you correctly you must of remove that center piece of cap and installed just the cap? How about replacing inner filter unit back to stock?
      02-17-2024, 11:00 AM   #7
iverson03tj
I replaced the inner filter as well.
Also while combing through ISTA, I see there is some sort of oil pressure control valve. No 11
https://www.realoem.com/bmw/enUS/sho...diagId=11_4447
https://www.fcpeuro.com/products/bmw...ve-11417622768
Could this be the reason why the oil pressure isn't high at start up?
      02-17-2024, 03:50 PM   #8
Conserve
You maybe on into something.
https://f10.5post.com/forums/showthread.php?t=1937902
