2010 2011 BMW 5 Series Forum F10 Review and dyno results of BMW F10 535i GSR Technik Stage 1 ECU Flash tune |
05-25-2015, 12:11 PM | #1 |
Dream crusher
984
Rep 2,421
Edit
IG: @bmwdoubles Last edited by Bmw doubles; 04-11-2016 at 01:34 AM.. Reason: Tune went currupt and don't want others to fall into a bad flash |
05-25-2015, 12:16 PM | #2 |
Dream crusher
984
Rep 2,421
Wanted to add a few more pics
IG: @bmwdoubles |
05-26-2015, 03:42 PM | #3 |
Dream crusher
984
Rep 2,421
Here is what I got 0-60 in a 6MT, in DTC mode, on 20" Dunlop SP Sport Max tires. I'm sure it could be better as I have not driven a stick in along time and still practicing the heel toe. Had to stop after the clutch started smelling funny.
I'm getting a CDV mod next week and Eibach lowering springs for my non m sport so we'll see if I get better by then. I was reading m sport in sport modes with 8 speed AT we're getting the same 0-60 times. I will say stick takes more skill.
IG: @bmwdoubles |
05-26-2015, 03:43 PM | #4 |
Dream crusher
984
Rep 2,421
Edit
IG: @bmwdoubles |
05-26-2015, 03:46 PM | #5 |
Dream crusher
984
Rep 2,421
Edit
IG: @bmwdoubles Last edited by Bmw doubles; 04-11-2016 at 01:35 AM.. |
05-26-2015, 05:00 PM | #6 |
Rep 1,250
Drives: 20' X3M CP
is 0-60 in 5.5seconds good in a 535i?
Glad you like your tune man. the V6 guys should jump on this.
2020 X3M CP - IND Reflector set | Ceramic Tint
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 | |
05-26-2015, 05:33 PM | #7 | |
Dream crusher
984
Rep 2,421
DP, intake, catback exhaust and stage 2 GSR Tune should give me a 5 second flat 4000lbs car. The tune has shaved .4 seconds from stock. http://www.edmunds.com/car-reviews/t...automatic.html
IG: @bmwdoubles |
05-27-2015, 07:15 PM | #9 | |
Dream crusher
984
Rep 2,421
e46beater states " that F10 DPs are capable of stage 2 before needing an upgrade". The guys at GSR can chime in on that. They did recommend a DP and full exhaust for better airflow and enabling a stage 2 tune. The JB4 is on my list next to get e85 support in the mix. That magic gas always is good for a few more unicorns.
IG: @bmwdoubles |
05-30-2015, 12:48 AM | #10 | |
Rep 383
Drives: F13 M6 | E92 M3 | '15 Mustang
We've started offering a Stage 1+ which is our Stage 1 with support for catless downpipe which really flattens out torque curve and gives you a little bit more on the top end. Really nice for a daily driver for someone who doesn't really want to go for hero numbers but wants something strong and smooth. The big benefit with catless DPs is being able to optimize the tune for the top end so you typically see much better gains with HP as opposed to TQ - much better pulls through the entire RPM range as HP takes over for TQ. We just tested JB4 running E30 alone and then our tune with JB4 running on top of our tune. Results to be published soon. |
05-31-2015, 10:44 AM | #11 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
the guy in the red shirt needs to stop skipping leg day lol.
they should be able to squeeze 470+wtq out of that motor easily with the stock turbo and DP's.
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
Jager535i6.50 |
06-01-2015, 10:56 PM | #13 | |
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
06-10-2015, 12:14 AM | #14 |
Rep 494
I'm assuming this tune is ill-advised for the 8 speed auto because the tranny is not rated to be able to handle anywhere near that amount of torque.
Max stated torque for the ZF 8HP45 used in the 535i/ix is 332 foot pounds. Is my assumption correct? Thanks
06-10-2015, 12:42 PM | #15 |
515
Rep 1,063
thats the same tranny in the f30 335 right? ive gotten 540wtq out of mine and no slippage yet.
06-10-2015, 12:43 PM | #16 |
515
Rep 1,063
not that I know of, I dont pay attention to the 5 series world so I cant really help you much there, but its the same motor in my car...so I dont see why not.
06-10-2015, 01:53 PM | #17 | |
Rep 494
Yes, the 535i and 335i share the same ZF 8 speed. Your 335 must be an absolute rocket! Dumb question, but are you frequently pushing the car really hard, or just occasionally? Any idea what the transmission temps are? From what I've read, once that tranny hits 220 degrees (200 is max per ZF) the lifespan is cut in half, and half again for every 20 degrees over that. |
06-10-2015, 11:03 PM | #18 | |
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
06-10-2015, 11:08 PM | #19 | |
515
Rep 1,063
And honestly no I don't, Its been with Eurocharged the past month for some R&D so I haven't had an opportunity to drive it much, but I'll be getting it back here in the next few weeks and I'll check out the temps. I've never heard that about the trannys lifespan...seems a little overkill imo. I guess it depends on the temps the tranny fluid can handle and I have no idea what those specs are. I drove around wth a jb4 on it for a year pushing 460wtq and I never had any issues with it if that makes you feel any better. But right now the car is at 560whp/541wtq. Ordered some colder plugs and a stage 2 LPFP so I expect those numbers to go up some.
06-10-2015, 11:55 PM | #20 | |
Rep 494
At certain temps the seals harden and the tranny fluid turns to lacquer (pretty much common to all auto trans) but based on your history it seems like the ZF is easily handling 50% more power than advertised. As I mentioned in another post, Dinan is warranting the drivetrain with their 392 foot pound tune, so that level of confidence helps as well. Thanks again. |
06-11-2015, 12:02 AM | #21 |
515
Rep 1,063
I looked up the ZF 8 tranny fluid and the "boiling" point is 536 farenheight so that gives me some comfort. I guess I'll find out the true capability of the tranny whenever the time comes that it fails lol
06-11-2015, 12:59 AM | #22 | |
Rep 494
Here's a chart showing temps vs. lifespan. http://www.txchange.com/heatchrt.htm |
