2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum F10 550i Puddle Lights
      08-29-2022, 03:42 AM   #1
Dif-one
Drives: 2013 550i
Soooo of the 4 doors only one of the puddle lights are working now. Is this a fuse problem? If so which fuses would control door lighting (located in glove or trunk?) Or do I need to tear into the door and see the wiring? Thanks in advance for any helpful advice.
      08-29-2022, 12:16 PM   #2
Unspec
Unspec's Avatar
1301
Drives: 2015 BMW 535xi
Probably just burned out bulbs.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      08-29-2022, 07:08 PM   #3
Aussie_550i
Australia
12
Drives: 2011 550i, 2017 430i
You can remove the lights from the door card without taking the door card off.
      11-05-2022, 02:26 AM   #4
Dif-one
Drives: 2013 550i
I was overthinking it. Yes new bulbs. Anyone know what kind they are by off chance?
      11-05-2022, 11:58 PM   #5
Qsilver7
Qsilver7's Avatar
Drives: F06 650ix GC / F15 X5 50i
Part database site? Went to LIGHT diagrams and looks like it’s probably #9, #4, or #2 which should be easy to verify if you:
  1. Open door
  2. Pull out light
  3. Look at bulb
Whichever light bulb it is, you can simply google “BMW xx xx x xxx xxx” (where x- the actual BMW part number)…or take the bulb to a local auto parts store to find a compatible bulb.
https://bimmercat.com/bmw/en/search/...0i/USA/63_1217
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
