2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum 535i xdrive oil pan gasket advice
      03-08-2021, 09:35 PM   #1
Egoy936
Drives: Bmw 535
Hello,
Has anyone replaced their oil pan gasket on an x drive car with the n55? I was changing the oil on my f10 today when I noticed the oil pan gasket was leaking (see photos below).
If anyone has done this or have any good guides I would love to see them. I am wondering if the subframe can just be lower or does it need to be fully removed?
Any advice would be appreciated.
      03-08-2021, 10:36 PM   #2
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
That's not too bad, closer to a seep than a leak. If you're not at the point of drips, don't worry about it. As the engine heats up the metal expands and re-seals it. It's fairly expensive/extensive of a job, hence the general recommendation to wait for it to drip.
Mine's been like this for 10k miles and I don't even need to top off between oil changes.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      03-11-2021, 12:09 AM   #3
chipguy
Drives: 12 528i
I would check the bolts and make sure they are torqued to spec. If you are lucky, maybe they got a bit loose.
Tags
bmw, f10, n55, xdrive
