2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes KW Suspension | V1 V2 V3 | F10 528i 535i 550i
      08-26-2015, 03:31 PM   #1
AutoTalent
AutoTalent's Avatar
2309
Drives: e92 M3 6mt | e60 M5 6mt
Please PM or email: Golan@AutoTalent.com with any questions!
KW Coilover Kit - Variant 1 (V1) - F10 528i 535i 550i
Part #: 10220080 Without EDC / 110220090 With EDC
Factory Pre-set Damping
The Variant 1 is KW's basic simple and effective coil over kit that is still packed with lots of features -
Pre-set damping optimized for a blend of ride comfort and handling with less bodyroll than the standard suspension,
Stainless steel strut/shock bodies and composite spring perches for superior corrossion resistance,
Individually height-adjustable - Front = 25-55mm lowering; Rear = 20-50mm lowering,
TUV approved lowering range and operation,
Expert engineering and design for ease-of-use and long durability,
This is the ideal coil over kit for a F10 5-series owner who does not plan on tracking or autocrossing the car and just wants a lower, more aggressive stance and better handling. KW has set the shock damping rates to be an excellent balance for a smooth yet taut ride, and to resist bodyroll motions for better handling. The Variant 1 differs from the Street Comfort set in that it has stiffer springs and revised shock settings. If you want a sportier ride and better handling than stock the Variant 1 is an excellent choice.
Coil over suspensions are better engineered suspension options compared to a standard shock + spring package. Since the springs and shocks in a coil over are designed by a team of engineers to work together, there is much better suspension travel and more precisely tuned specifications for spring and shock rates. Using separate shock and spring specs may result in premature coil bind or shock bottoming. And most coil over kits offer more features than the traditional packages. Coil overs are also more useful when larger wheels/tires are used because you can precisely set the ride heights to clear the new tires.
KW Coilover Kit - Variant 2 (V2) - F10 528i 535i 550i
Part #: 15220080 Without EDC / 15220090 With EDC
Adjustable Rebound Damping
The KW Variant 2 gives shock rebound control to give you more options in fine-tuning the handling of the car. The V2 includes the same features of the V1 kit, including -
Adjustable Rebound with fixed compression settings - optimal ride comfort then dial in more grip and a better balance with less bodyroll than the standard suspension,
This kit is an excellent compromise between a fully-adjustable V3 suspension and the basic V1 street kit. It's great for someone who does not want to make complicated and time-consuming shock adjustments. Just dial in the rebound for more grip and less body motions. Set it back for a compliant street ride.
KW Coilover Kit - Variant 3 (V3) - F10 528i 535i 550i
Part #: 35220080 Without EDC / 35220090 With EDC
Adjustable Rebound & Compression Damping
Want full control? The KW V3 gives you multiple settings for both rebound and compression. You have full access over ride comfort and handling to dial in that perfect setup. Race teams rely on adjustments to get that perfect lap time and having shock controls at your fingertips is key. KW V3 features -
Separate adjustments for compression (14 positions) and rebound (infinite settings),
Stiffer springs over stock for less bodyroll than the standard suspension,
Whether you track the car often or only use it for backroad carving the V3 will give you the tools to set up an ideal handling condition. You can crank it up for smooth and fast surfaces or soften it for city or rough roads. Since each shock is 2-way adjustable you can alter the front-rear balance to account for brake dive or squat during power application coming out of the corner. You are in total control!
      08-30-2015, 02:39 PM   #2
Mojave92
yunior
Mojave92's Avatar
Dominican Republic
18
Drives: 2018 430i Xdiver (f36)
Nothing for XDrive jet?
      08-31-2015, 02:11 PM   #3
AutoTalent
AutoTalent's Avatar
2309
Edit: Yes there is. Part # 352200BE
      08-31-2015, 03:21 PM   #4
exylyr
Drives: 2012 550i xDrive
I thought V3 was available for the 550i xDrive (from previous post)
KW Coilovers for xDrive 550 http://f10.5post.com/forums/showthread.php?t=1142792
      09-01-2015, 04:46 AM   #5
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Pm for 2011 535 KWV1's no EDC please!
      09-01-2015, 03:31 PM   #6
AutoTalent
AutoTalent's Avatar
2309
PM Coming!
      09-04-2015, 09:13 PM   #7
Mojave92
yunior
Mojave92's Avatar
Dominican Republic
18
2012 528i xdrive pm me price to 07087
      09-05-2015, 08:01 AM   #8
lsturbointeg
PM Coming!
Great price u guys... just got a quote and can't believe the price I got...definitely putting an order!
      09-08-2015, 01:27 PM   #9
AutoTalent
AutoTalent's Avatar
2309
      09-29-2015, 01:12 PM   #10
AutoTalent
AutoTalent's Avatar
2309
Bump!
      11-11-2015, 06:18 PM   #11
AutoTalent
AutoTalent's Avatar
2309
Bump!
      11-16-2015, 09:06 AM   #12
TJBentley
TJBentley's Avatar
Drives: '12 528xdrive
Bump!
Pm me price for 2012 528 xdrive shipped to 10310
      12-14-2015, 07:59 PM   #13
AutoTalent
AutoTalent's Avatar
2309
Bump!
      12-18-2015, 08:42 PM   #14
Highpriest0303
Drives: Porsche 918 Cayman S
Me too please, PM me the price for V1 and V2 for my 2013 BMW 535 XI M-Sport
Zip Code 11784
Thanks!
      12-20-2015, 03:16 PM   #15
TJBentley
TJBentley's Avatar
Bump!
Pm me price for 2012 528 xdrive without edc. V1 and v2
      03-07-2016, 01:22 PM   #16
AutoTalent
AutoTalent's Avatar
2309
Bump!
      05-17-2016, 04:22 PM   #17
AutoTalent
AutoTalent's Avatar
2309
Bump!
      05-26-2016, 09:53 PM   #18
splitsensetam
Drives: 2011 535i xdrive
Bump!
Please PM me price for KW V1 and V2 for 2011 535i xdrive. Thx
