2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Alignment and rear camber
      05-25-2016, 07:54 PM   #1
991PCAR
Drives: 550i M Sport
I just got my Michelin PSS's mounted (550i M Sport) today along with an alignment and added some rear spacers. The technician was asking if I wanted a more aggressive camber in the rear. I told him I like to drive spirited so we decided to add a smidge more......after it was off the rack he told me he set it at -2.2 vs. the -1.8 spec. Is this a little excessive? I probably should have just had him set it to spec....should I go back and have it redone or is .4 degrees not much of a difference?
Thanks!!!
      05-25-2016, 09:40 PM   #2
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Here's mine I just had done about a month ago and as you can see my rear camber specs -2.4 & -2.6. According to the tech that's pretty flat considerating I'm on 21's. So far after a month it's been good. No inner tire wear that I could see but it's probably too soon. I've taken the car through some pretty aggressive turns and it sticks!
