2010 2011 BMW 5 Series Forum F10 Removing turbos on N63, what should I change in the process? |
12-13-2017, 01:09 PM | #1 |
Rep 24
I am finally ready to replace "turbo oil return housing gasket" on 2010 N63 which is requiring removal of the turbos. Is there anything I should be replacing in the process in addition to the gasket?
Thanks, Vadim PS: cross-posting from 7post, hope to get more responses |
12-13-2017, 03:37 PM | #2 | |
Rep 659
12-13-2017, 03:40 PM | #3 |
Rep 2,062
Have them rebuild by Turbo Labs of America while they're out
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's '97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's |
12-13-2017, 04:02 PM | #4 |
Rep 24
I have oil leak which I can not track, but based on everything I could find, https://bmwtechnician.com/2015/09/27/n63-oil-leak/ looks like the best fit to the issue. I've had that leak for the last 40,000+ miles, it's just becoming worse, so I finally decided to do it.
12-14-2017, 10:38 AM | #6 |
Rep 122
Two reasons
1) more power 2) everything will be new, so you wont be taking them off again if this one gasket change doesnt solve your problem.
2012 F10 535ix - JB4 - BM3 - Meisterschaft GTC - coded modules - CF front lip - CF rear diffuser - clear bra
12-14-2017, 03:03 PM | #8 | |
Rep 24
"we can replace the wastegate arm and bushing if they need it. we can upgrade the compressor wheels to a 50mm compressor. The factory turbos make pretty good power. if you arent trying to exceed 600 hp, then you probably dont need a turbo upgrade." given that I am not tracking this car, I'll skip |
12-14-2017, 03:04 PM | #9 |
Rep 24
12-15-2017, 10:08 AM | #10 |
Rep 1,254
you have to find out serial# on your turbo here is link
it "ONLY EXAMPLE" what you should be looking for Rebuilt kit https://www.ebay.com/itm/T3-T4-TURBO...dZQ3Qf&vxp=mtr
12-15-2017, 10:41 AM | #11 | |
Rep 24
12-15-2017, 10:55 AM | #12 | |
Rep 122
I won't track mine either but you better believe I'm putting a big ass 71mm turbo on mine. lol
12-15-2017, 11:15 AM | #13 | |
Rep 1,254
I don't know what turbo you have best way to find out is call local BMW with VIN# they can provide 100% accurate info on your turbos. I don't have problem buying from ebay many manufacturers have ebay stores as long as you don't buy form China
12-15-2017, 12:42 PM | #14 | |
Rep 24
12-15-2017, 02:34 PM | #15 | |
Rep 2,062
You asked for advice on this thread and so far you've shut down all given to you. |
12-15-2017, 02:38 PM | #16 | |
Rep 24
I asked for the advice and I am looking for the advice on what to do with a car |
12-15-2017, 02:47 PM | #17 | |
Rep 24
I can not find rebuild kits in Gerrett's product catalog: https://www.turbobygarrett.com/turbobygarrett/ Turbos I have are MGT2256S. Any recommendations? |
02-06-2019, 06:32 PM | #19 |
Rep 24
