2010 2011 BMW 5 Series Forum F10 F10 Msport rims spacers??? |
01-06-2014, 06:44 AM | #2 |
Rep 29,202
Is it lowered? Lowered F10s can run bigger spacers, because the wheels cambers in. I got 10mm on the front and 18mm in the rear.
01-06-2014, 01:58 PM | #4 |
Rep 2,194
Bake
01-20-2014, 08:32 AM | #7 | |
Rep 2,194
Bake
01-20-2014, 03:48 PM | #8 | ||
Rep 654
You think 18mm spacers for stock Msport rims is to much? I'm deff going with 12mm for front, just can't make up my mind for back if I want to go 15mm or 18mm. |
01-20-2014, 05:12 PM | #9 |
Rep 138
I had 18mm on my stock 19's and liked the look. It's an aggressive look for sure. If you decide to go with 18mm, I have them in the for sale section pretty cheap. I'm no longer running stock wheels.
01-20-2014, 05:50 PM | #10 |
Rep 2,194
It is all personal preference. Personally I am happy with 10mm in the front and 15mm rears. Sits flush to me. I have ACS springs but they are not installed yet, so can't comment on how they will look once the car is lowered. Lowered cars have a bit of negative camber so 12mm/18mm might be a bit better for that. I am only running them for winter anyway cause my 20" summer wheels should be pretty flush.
Bake
01-20-2014, 06:34 PM | #11 | |
Rep 654
01-20-2014, 07:51 PM | #12 |
Rep 22
furreal? dude I liked ur HRE setup remember? didn't notice they'd been spaced.. what's your guys' opinion on going more? like 30mm in the back and 20 in the front? too much? why the subtlety?
01-20-2014, 08:40 PM | #13 | |
Rep 155
I've had good luck with these. Both with stock wheels and aftermarket on my E60 and F10. I have these in 5mm on my front wheels now.
DGM 550i
01-21-2014, 05:02 AM | #14 |
Rep 29,202
No spacers with the HRE. The spacers are on the OEM 351M that I use as winters.
01-21-2014, 10:50 AM | #15 | ||
Rep 432
01-22-2014, 08:54 AM | #16 | |
Rep 2,194
Bake
01-22-2014, 09:23 AM | #17 | ||
Rep 432
01-22-2014, 01:55 PM | #18 |
Rep 8,801
I recently put on a set of ECSTuning spacers on my staggered 19" 351M winter setup to make it alittle more flush. Went with 10MM up front and 15MM in the back. If i did it over again I would have went 12MM up front with 18MM in the rear. Since I am running 245 winter tires all around my rear still has plenty of room left before it is flush with the fenders.
BTW I am dropped on ACS springs as well. Alan
01-22-2014, 02:31 PM | #19 | |
Rep 2,194
Bake
01-22-2014, 06:52 PM | #20 | ||
Rep 138
02-11-2014, 12:30 AM | #21 |
Rep 375
Drives: 2011 535i Sport - P1, P2
I initially just had 15mm spacers on the rear. I lowered the car on ACS and decided to add 10mm spacers to the front. I am not that happy with the results as I feel like the front is more flush (if not a little wide) compared to my rears. Before the rear had a wider look, but the front spacer made it look square.
I get it that lowering the car pushes the camber in. I got an alignment and my front sits perfectly straight while the rear is still toed (BMW design). I think I will go with a 18mm or 20mm on the rear. I have a factory 19" staggered set-up. Btw, if you are selling a 18mm or 20mm spacer, let me know. I have the more expensive 15mm spacers on now. Anyone interested to buy or trade? |
02-12-2014, 12:01 AM | #22 | |
Rep 375
Here is the link of the pics of the front wheels before and after: https://plus.google.com/photos/11077...CLPawO6T_fzhUQ |
