2010 2011 BMW 5 Series Forum F10 Finally. Headlight switch w/ rear fog light button! |
04-11-2011, 05:19 PM | #1 |
Rep 158
Thanks to a good friend from Finland, I have now in my possession this:
http://twitpic.com/4edilf Now time to see if it is in fact a true plug-and-play mod. |
04-12-2011, 11:30 AM | #2 |
Rep 1,170
Drives: 2020 F97 X3M
That should be a sweet retrofit. The rear taillamps already have the recesses for the fog lamp bulb(s)- no?
2011 MINI CooperS BRGII/Lounge Green/Sport/Prem/Connect/Black Xenon/Black Conical Spokes/ACS springs/ACS exhaust/Alta Shorty/Yokohama Advan Sport A/S
2012 M3 AW/FR NDH2/2MK/ZPP/ZCP/ZCW/752/6NR/OEM CF splitters/OEM CF Mirror caps (retired) 2012 X3 35i Titanium Silver/Black ZAP/ZPP/TECH/APPS/Breyton GTS (retired) 2018 X3 M40i BSM/Oyster/ZPP/ZPX/HK/S6CPA/718M(retired) |
04-21-2011, 02:31 PM | #3 |
Rep 158
just received confirmation from my service advisor that the headlight switch can be coded to work! no additional parts needed - true plug and play. i am only being charged 1hr labor for removing the trim piece and coding the new switch.
finally, a working rear fog light in the 5GT. |
04-21-2011, 02:57 PM | #4 | |
Rep 514
Drives: 745le xdrive 2020, i3 2020
rear fog ligt in gt
some pic. |
06-27-2011, 07:05 PM | #7 |
Rep 158
alextremo - 'coding' by the dealer meant a couple of clicks on their computer to have it work.
qmanisi - new switch works flawlessly. (the headlight aiming toggle is inop, as i don't have that feature). switch without that toggle is: Control Element Light: 61319192746 http://realoem.com/bmw/showparts.do?...75&hg=61&fg=35 |
06-27-2011, 07:25 PM | #8 |
Rep 966
Yeah, thats the problem - "couple clicks on their computer" = trip to the dealer and $125 here...
Not the end of the world, but definitely not plug and play. On my last car I popped out the trim by hand, unclipped the old switch, clipped in the new and pushed the trim back on - thats it. I wonder if this is something dvdinmotion can code with a custom cd? |
06-27-2011, 08:00 PM | #9 | |
Rep 1,170
Kind of like the new 2011 Mini's I also wonder if those lights illuminate as part of the panic braking system - anyone know?
06-27-2011, 09:07 PM | #10 |
Rep 4
Hi
I am trying to get similar thing done in Boston area so do you happen to have any details of 'what should they change in sw' to enable the rear foglight? I got the switch already and will get it installed tomorrow. Just worrying that the service here has no clue what to do =) Thanks for the great news! |
06-30-2011, 07:38 PM | #12 | |
Rep 966
PM me if your'e interested. |
07-01-2011, 12:21 AM | #13 |
Rep 158
You need the BMW service center to activate the button. I negotiated .5 hr of labor for them to install and code. Most of labor was for them removing/reinstalling trim piece to get to the new switch in.
If you install switch yourself, might be able to negotiate for lower labor rate... |
07-01-2011, 02:05 AM | #14 |
Rep 4
I got the switch installed but the local BMW service center didnt know what/how to program the switch, thus my question of who did the programming for you so they could call'em or at least I could again make a case that it a) can be done and b) 'these guys did it'
seems BMW North America was not happy to help either or something crazy. |
07-03-2011, 07:26 AM | #16 |
Rep 4
No Luck
No Luck. The BMW Gallery Norwood was not able to do it, even when they tried to open incident with BMW North America.
Does anyone know any good 'tuning shops' within Boston area that maybe could tune SW settings and line items? I need both the Radio changed to ECE (even channels also) and Rear Foglight enabled. This is veeeery frustrating =) |
08-29-2011, 06:29 PM | #17 |
Rep 7
I had a friend pickup a switch for me on a recent trip abroad. I just swapped out the old one with the new switch which has the "Rear Fog" button and it worked without a trip to the dealer.
It was a <5 minute job and required no programming. This is on a May/2011 build 535i. Clay |
12-18-2011, 05:52 AM | #18 | |
Rep 41,150
Drives: 2018 Alpina B6 650ix GC
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
01-27-2012, 01:13 PM | #19 | |
Rep 2
01-27-2012, 02:25 PM | #21 |
Rep 966
It was PnP for me - pull off the trim by hand, unscrew and unplug the old switch, plug and screw in the new switch, push trim back in place.
Rear fogs, fog light dash indicator and all other switch functions work fine after this. |
01-27-2012, 05:34 PM | #22 | |
Rep 41,150
http://www.ecstuning.com/BMW-F10-535...hes/ES2497350/ http://euroactiveparts.com/product_i...oducts_id=2003
