2010 2011 BMW 5 Series Forum F10 trip preparation question... |
05-03-2011, 06:53 PM | #1 |
Rep 852
so I'm planning a long trip with my f10 (about 3000 miles) and i'm going to do it on my 20's with hankook tires, now I'm thinking to take my 17" winter wheel just in case as backup, if something happens and I put on that 17" wheel, will it be fine? nothing will happen to alignment or to the suspension? or what would you advise ?
05-04-2011, 01:13 AM | #2 |
Rep 1,134
Personally, not into the 20's fad or even understand the reason for them but, more importantly, where are you going to put a set of 17" tires/rims in your car and still account for any luggage for a 3000 mile trip? Are you solo'ing it?
2014 550i M-sport
05-04-2011, 01:22 AM | #3 |
Rep 2,248
I think the op is proposing one 17" wheel as a spare. It should work fine. The circumference is the critical measure and it must be close to the same. Of course the car will not handle properly with one unmatched tire, so you would have to drive conservatively.
05-04-2011, 07:21 AM | #5 |
Rep 519
Although you can certainly drive on one 17" Wheel, with the other 3.... 20's, but there is a chance that the car will throw some codes or warnings at you as a result of sensing the difference in rotation speed. I am not sure though if this will happen. You might want to send a note to Mike Miller at the car club and see if he knows.
05-04-2011, 05:38 PM | #7 |
Rep 852
05-04-2011, 05:59 PM | #8 |
Rep 4,721
If you don't bring your 17" as spare, at least BMW Assist can help you in some way. But at least bring an electric air pump & 2/3 cans of tire sealant.
05-04-2011, 07:22 PM | #9 |
Rep 351
Just join the Auto Club and call them if/when you get a flat. I have a CSAA (auto club) membership and I carry a BMW jack, lug wrench, hi-power air compressor and a plug kit. All this stuff uses very little space at the back of the trunk. I don't need (or want) a spare in my trunk
05-04-2011, 07:27 PM | #11 | |
Rep 852
05-04-2011, 10:01 PM | #12 |
Rep 351
Compressor:
http://www.amazon.com/gp/product/B001D5HP40 It's terrific, it inflates a big tire in no time. You don't want to use your cigarrette lighter because it will burn the fuse. Use this instead and connect directly to the battery in the trunk: http://www.amazon.com/gp/product/B00065L2D8 This is the plug kit that I have never used and hopefully never will. I have no idea if it is any good but it doesn't look too cheaply made: http://www.amazon.com/gp/product/B000IHK02I |
05-05-2011, 05:38 AM | #13 |
Rep 4,721
For the Cdn model, F10 uses indirect tpms sensor located in the ABS system. Unlike the US, it uses direct tpms sensor which is located inside the wheel.
06-17-2011, 09:50 AM | #14 | |
Rep 18
I'm sure the wheels (with tyres fitted) will have a similar overall diameter, so rotation speed will be the same. My 17" and 20" certainly do- otherwise the speedo would be wrong. |
06-17-2011, 10:55 AM | #15 | |
Rep 185
3000 miles = 4 828.032 kilometers. I've done those kind of trips with my 3-series E92 3 times without no spare wheel. There are tires shops all over Europe here. Its not that big of a problem. Drive safe! |
