2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Quick Exhaust flap "stay open" mod
      04-05-2015, 01:29 PM   #1
dadysev
dadysev's Avatar
Montenegro
169
Drives: Man
If you just want to keep the flaps open all the time. just do a vacuum line bypass.
The solenoid is behind the left rear tail light. You have to open the rear left inner panel to access it.
The whole thing took me less than 10 minutes. you just need a plastic panel puller and small flat screwdriver to help get the vacuum lines off the solenoid, and find a small plastic tube to join the two vacuum lines.
pic attached.
      04-05-2015, 02:02 PM   #2
badblack550xi
badblack550xi's Avatar
harder than zip tie method.
2011 550i RWD 60-130 7.35
      04-05-2015, 06:08 PM   #3
Mbbrewer
Mbbrewer's Avatar
150
Drives: 550i
Agreed. Zip tied takes 30 seconds. Pointless mod on stock exhaust though.
      04-05-2015, 10:03 PM   #4
dadysev
dadysev's Avatar
Montenegro
169
Drives: Man
not stock, M5 mufflers.
      04-05-2015, 10:18 PM   #5
badblack550xi
zip ties work on M5 also
      04-06-2015, 12:04 AM   #6
Simple5
Drives: F90 M5 and E84 X1 Xdrive35i
Nice alternative for those that don't want to deal with zip ties.
      04-06-2015, 05:17 PM   #7
Chili Palmer
Master Of My Domain
Drives: 2015 650i Gran Coupe
Maybe I'm a lameass, but I couldn't get the zip ties to work on the M5 valves, there doesn't seem to be a place to tie off the zip tie to hold the valve open.
RIP: 2015 Black Sapphire Metallic 650i Gran Coupe, 343 Wheels, Michelin Pilot Super Sports 255 F / 285 R, M6 Front Grilles. Coming - M6 Comp. Mufflers, Carbon Fiber Diffuser & Spoiler.
      04-28-2015, 09:59 PM   #8
///M5Driver
Drives: gaggle of BMW's
Honestly this is fantastic since I tend to hear my valves rattle after the zip ties start to wear out. Great post thanks a lot.
      04-28-2015, 10:01 PM   #9
dadysev
dadysev's Avatar
Montenegro
169
Drives: Man
I did one more little mod till I customize my own remote switch.
Basically cut the negative switched wire to the solenoid ( I think it was brown with a stripe) and fed it to a switch. One side of the switch is ground so if I want normal operation I flip the switch one way. If I want fully open I flip the other way. It's under the rear trunk floor flap. Just until i do the remote switch.
AlexL4.50
      04-29-2015, 12:13 PM   #10
///M5Driver
Great idea as well!! I might add this now that I'm catless. Thanks man!
      04-29-2015, 01:12 PM   #11
///M5Driver
So this took me literally 30 minutes lol. The switch is temporary as it's all I had laying around the garage. I plan on getting a flush toggle like your photo.
Pull 4 tabs on lower trunk latch trim and unplug 12 volt adapter. Pull the three pins holding driver's side trunk liner in. Cut the brown/white wire and connect two wires to run into the cabin. Tuck them under the liner going towards the rear of the back seat.
The rear cushion pulls straight up and has two tabs under each seat. Shine a light so you can see a place to run your wires from the trunk.
Run wires under the seat and tuck up drivers side door sill trim all the way to the front. Pull side dash panel starting front closest to you (hinges at the back).
Unscrew two torx (T25 I believe) holding in storage container and pull gently outwards.
1/4 drill bit and switch installed
Can't even tell it's there (Flat toggle will be even better)
      05-07-2015, 10:07 AM   #12
///M5Driver
Just a heads up I did this mod while my car was down. After stage 2 installed I noticed it wasnt working haha. Maybe it's the power wire that needs tapped versus the brown ground wire. I'm going to switch it today.
      05-07-2015, 10:11 AM   #13
dadysev
dadysev's Avatar
Montenegro
169
Drives: Man
Make sure you ground the right wire! It has to be separated. BMW runs switch B+ Power to one side and the DME grounds the other side to complete the circuit. You must split the wire and ground the solenoid. Don't just ground the wire while attached !! You could damage the transistor in the DME
      05-07-2015, 10:24 AM   #14
///M5Driver
Oh sorry I misread your post! I just intercepted the ground side of the solenoid and added the switch to remove ground. So the circuit is normally open and needs ground applied to open the solenoid is what you're saying?
      05-07-2015, 07:46 PM   #15
dadysev
dadysev's Avatar
Montenegro
169
Drives: Man
Forgive my grade 1 drawing. See if you can follow it.
      05-08-2015, 01:52 PM   #16
gclions
gclions's Avatar
78
Drives: 2011 550i
Did this mod in an Advance Auto parking lot a few minutes ago, stock exhaust so no real increase in sound, but the rattle on startup is gone.
The dealership replaced the driver's side muffler under warranty to get rid of the rattle on one side, but the other flap still rattled. So, if for no other reason this was an easy enough modification that got rid of a small annoyance with the car.
Thanks for the original post, but I'll leave wiring switches to the rest of you guys.
2011 BMW 550 i / Sophisto Grey / BMS Stage 2
      05-08-2015, 04:05 PM   #17
dadysev
dadysev's Avatar
Montenegro
169
Drives: Man
Yeah you wont hear much with stock mufflers. Like I said I have M5 mufflers on which make a huge difference on sound. The flap really keeps them quiet when closed.
      05-08-2015, 05:44 PM   #18
///M5Driver
So oddly enough mine rattle whilst open.. I think I'm gonna go back to the zip tie method as it looks like it applies more tension when they're open.
      05-09-2015, 11:28 AM   #19
gclions
gclions's Avatar
78
Drives: 2011 550i
Well, mine started to rattle after coming back to an idle. So I switched it back. Not 100% sure, but it felt like there was a noticeable loss in low end torque, so even if it didn't rattle I likely would have switched it back.
Still a very cool mod if you have the exhaust setup to really enjoy it.
      05-18-2015, 10:50 AM   #20
BIGW0RM
You got my money?
BIGW0RM's Avatar
Drives: Ice Cream Truck
2022 BMW M3  [9.50]
That sucks. Ive got a M5 and it made a pretty big difference. But you're saying the 550 wont be that noticeable?
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
      05-19-2015, 08:22 AM   #21
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
I'm new to the 5 series world coming from my e90 where this was the first thing I did. It made an audible difference, but was wondering if this is the case for an F10 535i?
On my my e90 I ended up plugging it back in and set the JB4 G5 to have the flaps always open.
IG: @bmwdoubles
      05-19-2015, 11:23 AM   #22
dadysev
dadysev's Avatar
Montenegro
169
Drives: Man
550i muffler is really restricted. If you look inside the can it has some loops to klll the sound versus the M5 which is almost straight through.
Never did test it on the OEM 550 cans though.
The left is the M5 and the right is the 550
