2010 2011 BMW 5 Series Forum F10 20" wheel offsets for 535i? |
12-02-2014, 02:01 AM | #1 |
Rep 22
I apologize if this has been answered numerous times before....but what are the correct front and rear offsets for 20" wheels on a 2015 535i m-sport? I'm thinking of picking up a set of staggered 20x8.5 and 20x10 wheels from EBay with offsets et35 front and et40 rear. (I believe they are a leftover set of Avant Garde m355s)
Will these fit without any rubbing or fender trimming? Thanks in advance I'm a learning newbie! |
12-02-2014, 03:01 PM | #2 |
Rep 494
Here's the info I have comparing to the M5 stock wheels, which do fit the non-M 5 series cars (I believe this info was gathered by Shawn in another forum).
The 295's are pretty tight, so 275 or 285 rears are better. Stock 19" F10 535i M-Sport 19" M Double Spoke Style 351M Cast Wheel Set Front Wheels - 8.5JX19 ET:33 - 245/40R19 - 14,53 kg 32 lb Rear Wheels - 8.5JX19 ET:33 - 245/40R19 - 14,53 kg 32 lb Rear Wheels (if staggered setup ordered) - 9JX19 ET:44 - 275/35R19 - 14,51 kg 32 lb Non-M F10 19" and 20" wheels are 19x8.5 ET33 and 19x9 ET44. 20" F10 M5 20" M Double Spoke Style 343M Forged Wheel Set Front Wheels - 9JX20 ET:34 - 265/35R20 - 11,20 kg 24.7 lb Rear Wheels - 10JX20 ET:34 - 295/30R20 - 11,70 kg 25 lb Last edited by SonicEndeavor; 12-02-2014 at 03:16 PM.. |
12-02-2014, 03:20 PM | #3 | |
Rep 413
12-02-2014, 03:35 PM | #4 |
Rep 25,989
Here's an example of 20x9 ET35 | 20x10 ET35 (no rubbing or fender modification!)
Link to the full mod list: http://www.velocitymotoring.com/v710...-bmw-f10-535i/[/QUOTE]
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
12-02-2014, 05:04 PM | #5 | |
Rep 22
Thanks for the pics. Does the car in the photos use spacers? If so, how many mm front and rear? Is there a way I can calculate how many mm spacers I will need for a given offset number? Just trying to ensure I pick up all of the correct gear!
12-02-2014, 05:27 PM | #6 | |
Rep 22
Is the ET 35 number a measure of the offset in mm? And to figure out the required spacer do I just subtract the OEM wheel offset from the offset of the wheel I am considering? (Ex: ET35 - ET20 = 15 mm spacer?? |
12-02-2014, 05:41 PM | #7 |
Rep 494
The 20" specs I posted above (ET 35) will give you a flush setup. You can adjust from there as needed. Yes, offset is in millimeters from the center.
12-02-2014, 06:00 PM | #8 | |
Rep 25,989
No spacers used on that car True plug-n-play setup If you wanted to add spacers to help push the wheel out further to the fender, feel free to reference the links below: EX: ET35 + 5mm spacer = ET30 (5mm further out towards fender, 5mm further away from suspension) http://daliracing.com/v666-5/catalog...k-your-gap.jpg http://www.1010tires.com/Tools/Wheel-Offset-Calculator
12-03-2014, 01:17 AM | #9 | |
Rep 413
12-03-2014, 09:45 AM | #10 |
Rep 22
Thank you so much to all who have responded with advice, I really appreciate it. With all of your help, I think I have this sorted out:
Stock staggered M-sport wheels are 19x8.5 ET 33 front, 19x9 ET 44 rear New wheels are 20x8.5 ET 35 front, and 20x9.5 ET 40 rear. Using the calculator provided by VMRWheels, this gives: Front: 2mm less inner strut clearance and 2mm inward retraction from fender Rear: 2mm less inner strut clearance and 10 mm outward extension from fender Given these small numbers, am I correct in assuming that I won't need spacers for the front? (certainly not for the rear!) Also, can anyone recommend a high quality non-runflat tire that does not generate too much road noise?? |
12-03-2014, 10:27 AM | #12 |
Rep 494
It depends on what type of tires you need(summer, all-season, winter)
If you're going to run 265's up front and 295's in the rears (same setup as an M5), then Michelin Pilot Super Sports are a great choice, 285's or 275's then Pirelli P Zeros. These are all summer performance tires though. Check www.tirerack.com for options. |
12-03-2014, 10:36 AM | #13 | |
Rep 22
12-03-2014, 10:40 AM | #14 | |
Rep 413
The best summer tires are Michelin Super Sport. Then Pirelli P Zero and Hankook V12 that are cheaper. For 8.5" front and 10" rear you'll need 245/35ZR20 and 285/30ZR20. Wheel specs for BMW F10 = PCD 5x120, centre bore 72.5mm and M14x1.25 bolt thread. ET 33-44 http://www.bmwforums.info/bmw-wheels...olt-sizes.html |
12-03-2014, 12:22 PM | #16 | |
Rep 22
12-03-2014, 01:04 PM | #17 |
Rep 413
I would say, both setups are fine, either 245/35/20 front with a 275 or 285 (slightly better)/30/20 rear. It depends on your future plans on your rims+tires. The 275 rear is a bit cheaper and sits better on the 9.5" wide rim, so if you won't replace the rims later, stick on the 275. If you will replace them with 10" wide rear, then have the 285.
12-04-2014, 10:25 AM | #18 |
Rep 22
Thanks again guys. So I did a search on tire rack, and found the following tires (all summer performance, 285/30ZR20):
Bridgestone Potenza S-O4 - $253 Bridgestone Potenza RE760 - $230 Hankook Ventus V12 Evo2 - $243 Michelin Pilot Super Sport - $347 Pirelli P Zero - $381 Yokohama S.drive - $244 Any recommendations? Any specific ones to definitely avoid? |
12-08-2014, 01:00 PM | #19 | |
Rep 2,196
I am running the Hankook's and think they are great tires for the price. I have had Michelin Pilot Sports on other vehicles and agree it is a better tire, but it is also a premium price for those. Just my $0.02.
Bake
12-09-2014, 01:20 AM | #20 |
Rep 22
Thanks! I plan on getting the Hankooks. How is the road noise compared to the stock 19" run flats? Quieter? Also, is the ride quality overall softer and not as harsh? I've had RFTs on earlier bmws and found them a bit harsh.
12-09-2014, 03:18 PM | #21 | |
Rep 25,989
The Hankook V12 EVO2 and Noble S12 are well known for being an excellent bang-for-your-buck tire. Check out TireRack.com, they have comprehensive reviews on a lot of different options.
12-10-2014, 11:43 AM | #22 | |
Rep 22
