2010 2011 BMW 5 Series Forum F10 20" wheels - How Wide in the Rear? |
03-31-2021, 07:13 PM | #67 | |
Rep 10
Javier P
04-01-2021, 11:40 AM | #68 |
Rep 10
Im buying the same setup, do you have pictures?
Javier P
04-01-2021, 12:20 PM | #69 |
Rep 63
This is what one of my quotes recommended:
TOYO PROXES SPORT Ultra High Performance Summer 245/35R20 275/30R20 I'm in the exact same situation and am two weeks out of delivery of my F14s.
2017 M Sport 540i in Graphite
04-26-2021, 10:56 PM | #71 |
Rep 10
I'm running 20x9 ET+35 front's with 10mm spacers so ET+25 on 255/35/20 and 10.5 ET+40 rear's on 285/30/20 NITTO INVO tires, 2013 535i Xdrive M sport lowered on H&R sport springs, no rubbing at all with 5 people in, it actually drives awesome.
Javier P
Blue Angel999.00 |
05-16-2021, 02:07 PM | #72 |
Rep 8
I am always so lost on the spacing vs all other spacing.
I just bought myself a 535i 2013 and want to go with the biggest tires I can go with on my car. The picture below with Size: 20×9.5 | 20×10.5 is exactly what i want but the rim size does not specify what the offset should be. I don't really understand what the offset means either https://curvaconcepts.com/c300-bmw-535i/ I can buy them from here https://www.bbwheelsonline.com/curva...1051273073BLK/ 20x10.5 Blank (Custom Drilled BP) Gloss Black 30MM 20x9.5 Blank (Custom Drilled BP) Gloss Black 30MM Is the 30mm spacing fine for my car? is the difference notable say if I got 35mm spacing? Thanksa to anyone who probably has answered this question a 1000 times |
05-17-2021, 06:13 AM | #73 |
Rep 1,038
30 is not enough on the back, you'll want 40 for a 285 tire and min 45 for a 295 tire in my opinion. This is based on what others here are using. Some claim success with more aggressive fitment, but that's starting to cut it real close.
05-17-2021, 01:14 PM | #74 | |
Rep 8
Thanks for the reply. Can I just buy a 10mm spacer for my back and that fixes the issue. I am very clueless about spacers and the whole offset thing. Thanks again for the help |
05-17-2021, 03:51 PM | #75 | ||
Rep 29,202
05-18-2021, 09:13 PM | #76 | |
Rep 8
Thanks again for the help so for my back i want to go 20x10.5 @40mm and the front would be the 30mm be fine? |
05-19-2021, 05:52 AM | #77 |
Rep 1,038
Those offsets should work but may depend on your tire choice. A 295 will be tight on a 40 offset, so if you can't get 45 you may need to stay with a 285.
Once again, many claim they can go more aggressive but I would err on the side of caution unless you want to tinker to get the fit just right. This could include changing tire/wheel sizes/offsets and playing with alignment settings, and will depend on whether you are lowering the car or not. If you are not lowering the car, more aggressive fitments can stick out or "poke" which looks bad, in my opinion. The tires move inwards as the suspension compresses, so a lower car will support a more aggressive fitment than one that sits at stock ride height. Your best bet would be to do some research; look at a lot of pictures and ask lots of questions about the wheels you're buying. Be comfortable with the purchase ahead of time. Good luck! |
