2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Will 245/45/19 fit my 5er without rubbing?
      04-18-2012, 02:58 PM   #1
Khurram
Khurram's Avatar
49
Drives: 2012 Panamera 4
Hey guys quick question.
Will a 245/45/19 set fit my 535i base sedan without rubbing or interference?
I currently have a 245/40/19 which is fine but need to confirm about a 245/45/19 setup.
Thanks!
      04-18-2012, 03:24 PM   #2
bobblehead
bobblehead's Avatar
Drives: warp speed
Your speedo will be off by a 4%.
Overall diameter is also off by 4%. That's 1 inch too big on the proposed setup.
Not recommended.
      04-18-2012, 03:25 PM   #3
gatoman39
gatoman39's Avatar
Drives: 2011 E92 335 M-Sport
it's not rubbing you should be worried about. You changed the rolling diameter of the car over 3.5%. Speedo errors,worse gas mileage, car may pull, alignment issues. Not worth it. Go 255/40R19.
tet0010.00
      04-18-2012, 05:10 PM   #4
Khurram
Khurram's Avatar
49
Thanks for the answers.
So my wheels are 19x9.5 and 19x8.5 oem 331.
What is the oem setup for this wheel set? Non xdrive vehicle
      04-18-2012, 05:11 PM   #5
Khurram
Khurram's Avatar
49
Would 245/40/19 all around be better or would I definitely need to do a staggered setup?
      04-19-2012, 10:28 AM   #6
remmib
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
The 331 are 19x8.5 ET33 245/40/19 and 19x9 ET44 275/35/19.
Buddys550169.50
      04-20-2012, 02:43 AM   #7
WR11
WR11
Sweden
Drives: 2012 / 520d / alpinewhite
I have 245/45/19 Dunlop tires on my 5 series. no problems what so ever in ride, I know that my speedo is a litle bit off but I dont care. the wheel arch looks much better filled up now than with low profile 245/45 in my oppinion.
      05-19-2012, 05:53 PM   #8
FatTire
elev 8200'
FatTire's Avatar
Drives: 2012 550i xDrive
NO Problem with 245/45r19
I agree with WR11, the 245 45 19 works great and fits the wheel well better.
The overall diameter is 27.7 and is the same diameter as the 245 40 r 20/ 275 35 20 which I will be running on my 550 xdrive. BTW one can run staggered wheels on the xdrive. Just make sure all your tires have the same diameter.
My last 3 BMWs speedmeter read 2-3mph slow....tested by radar and GPS and the inch taller tire actually corrects the true speed. I've talked to several Dealer Service Depts about this and they say that the factory is within the margin or error 3-5%.
      10-14-2014, 11:52 AM   #9
Greenwich1
Drives: BMW F10 535i
I Have a 535i M Sport pack. I have the staggered rims. I just purchased 245/45/49 Goodyear LS2's that came off a 7 series. All four tires are the same size. They Fit perfectly, even on the back rims that are wider. It looks so much better, It fills the wheel well up perfectly. The ride is much smoother, I go over potholes with ease! I dont understand why BMW doesnt approve this, They want you to keep cracking rims and buying new tires.
I highly recommend doing it!
      11-26-2014, 06:48 PM   #10
SoDigito
SoDigito's Avatar
Drives: 16%E2%80%99 X6 / 10%E2%80%99 5
I am thinking of get 245/45R19 Dunlop run flat winter tires for my 2011 535i xDrive because there is simply not enough options in the 245/40R19 size. It's good reading about your experience. Hope I don't run into any issues, otherwise this could be an expensive experiment.
      03-30-2019, 04:18 PM   #11
Tevzadze2.0
Drives: 2011 Bmw 535 xi
Hey I have 245/45/19 square on my 2011 535xi
Also using alzor 730 wheels ( replica 313 wheels ) . I think the fit is perfect and
Beefy looking . Only f10 I've seen with these wheels
      03-30-2019, 10:16 PM   #12
Supahone
Supahone's Avatar
Drives: 11 550I, 07 335I,
On my 2011 550i xdrive I have 275 35 19 rears and 245 40 19 fronts on a staggered set msport package.
      05-04-2019, 06:31 AM   #13
Beemerjunkie
Drives: 2011 535xi M-Sport
I have the 245/45r19 Dunlops on my wheels for winter use and it completely changed my winter driving experience here in the Northeast. No issues so far and wasn’t weary of potholes.
Definitely recommend this upgrade.
      05-21-2019, 02:16 AM   #14
kstoyanov
I went for this size 255/40R19 (with new wheels 8.5 ET35) and the computer wont register the new wheels/pressure..? Is it because they are too large?
I drive 535i and apparently I don't have the TPMS system, only collecting the rolling from the ABS sensors. I visited multiple shops, they are clueless.. and BMW told me to go for the recommended BMW size tires/rims.
Anyone having this issues? I am worried that this bigger size wheels may cause other wearing out of modules and mess up the gear shifting..
      05-21-2019, 02:21 AM   #15
kstoyanov
Here are the errors:
      07-18-2019, 11:40 PM   #16
rojodo
rojodo's Avatar
Drives: 2013 535I 6sd
Are you using the same tpms with new tires? I think you need to use the same tpms you were using with the original wheels.
      06-11-2020, 06:37 AM   #17
faust_nick
Drives: 2014 535xi
Sorry to bump an old thread but are you lowered? Or is that all from the larger tire size?
      06-14-2020, 10:18 PM   #18
Tevzadze2.0
That pic it's not lowered , it's lowered now though .
      06-15-2020, 05:08 PM   #19
CanadianTSi
CanadianTSi's Avatar
Drives: 2014 535 xDrive Diesel
No rubbing or anything? have any pics of it lowered? thanks
      06-15-2020, 06:02 PM   #20
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
I ran 245/45/19 275/40/19 on 351, no issues. Only did that as I had a good set.
      01-07-2021, 07:25 PM   #21
Tevzadze2.0
No rubbing , drives fine
      01-25-2021, 10:34 PM   #22
Blue Angel
Blue Angel's Avatar
Drives: 2011 323i and 2016 535d
100% BS
The F10 speedo reads slow, a 245/45-19 fixes this. I'm running this tire size for winter and my speedo is now perfect. My odometer reads 3.5% low, but I can live with that. Same story with my Wife's E90; did this 10 years ago (+1" tire diameter), still drives great today.
The rest of your concerns are not valid. 7 Series runs this size tire from the factory and suffers from none of the horror stories you tell. Neither does my F10.
The only thing to be "afraid" of is rubbing if you have the wrong offset wheel; since the tire is taller it may be more likely to rub. Solution? Don't use the wrong wheel offset. Probably not a good idea to do a big drop on lowering springs, either.
I'm running the 408m wheel (OE M5 winter wheel) which is 19x9 square and has 32/25 F/R offset vs the stock wheels at 33/44 and no rubbing to report with the new Michelin X-Ice Snow in 245/45-19. 2016 Canadian 535d M-Sport (530d elsewhere).
