2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum 6WB Multifunctional Instrument Panel Retrofit
      01-01-2014, 03:23 AM   #67
kip1
Drives: X5M50d
Originally Posted by Patrys@BimmerTech View Post
Happy Holidays Everyone!
The 6WB Multifunctional Instrument Clusters are on sale now!!!
Check our website at www.bimmer-tech.net for more details.
Limited stock!!!
Does this work on F15?
      08-12-2014, 06:51 PM   #68
1aBimmer
Sweden
Drives: 530D
Hi guys..
Is there different 6WB for diesel and petrol (benzin)?
Or its the vehicle VIN and coding which set that?
best regards
      08-04-2015, 01:37 PM   #69
wheresmy5
Drives: 2019 540i xDrive M Sport
Originally Posted by JNoSol View Post
Very nice. I'm sure the '14 F10 LCI in the U.S will offer this, as the '13 F01 LCI got it. This is a great alternative for those who are not trading up next summer.
I'm confused. Do the LCI models offer this? I have a 2015 and don't see this when I select sport+, but maybe I'm doing something wrong...
      08-04-2015, 01:45 PM   #70
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
If you have 2015+, you have a digital cluster. You'll have to go into your settings to make the changes. I had a 2015 F06 and it had a digital cluster.
Daily: G12 750 MSPORT Weekend Car: E90 M3
      08-04-2015, 07:52 PM   #71
wheresmy5
It does work, but only when the HUD is turned off. However, I've not gotten the top half of the cluster to light up. Not sure what that part would show.
      08-04-2015, 09:53 PM   #72
JNoSol
JNoSol's Avatar
That doesn't sound right. The cluster on the HUD should go into sport mode. You need to take your car into your dealership and talk with the BMW genius.
See photo below. It should look like that in sport mode in the right setting.
      08-05-2015, 08:17 AM   #73
wheresmy5
Which settings did you change?
I don't think that I have the same panel.
      08-05-2015, 09:27 AM   #74
JNoSol
JNoSol's Avatar
Sorry, I just notice you have a 5 series. Only 2015+ 6 series and 2014+ 7 series have the all LCD cluster.
      08-06-2015, 04:20 PM   #75
TimeFor
TimeFor's Avatar
Drives: 2019 i3S REx
This is the primary reason I'm buying another F10 instead of a F01. I just don't like this cluster in person. The Extended Black Panel cluster of the F10 is simply nicer and easier on the eye. I like the blend of analog and digital. Any manufacture can just stick an LCD screen there and make the cluster look like a video game. Having analog style dials and a blend of black panel LED/LCD technology is much more of an engineering accomplishment. The same full digital display is on the G11 so this is the future I guess
      08-09-2015, 01:22 PM   #76
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
On mode
IG: @bmwdoubles
      08-11-2015, 07:29 AM   #77
BMWrules7
Drives: 2015, 740 LdX, Alpine White
Originally Posted by Bmw doubles
On mode
Initially, I preferred the analog cluster. I thought the digital clusters fuel gage and oil temp looked toyish.
You see, even on the full lcd, the fuel gauge and oil temp are analog. But, they made them 2d and not 3d so they won't compete with the 2d speedo and tach.
But, I have grown used to it and I like it.
I like it because there is better integration with speed limit signs. The digital cluster shows a red zone when speed limit (local) exceed.
      08-19-2015, 05:05 PM   #78
TimeFor
TimeFor's Avatar
The thing that sold me on the analog display being better than full digital was the cruise control setting. Its so amazing. There are a ring of hidden OLED's around the circumference of the speedometer for every mile per hour. These individual OLED lights up for the specific speed you set. On the F10 the color is amber when you have not yet reached the speed and a green one lights up when you're at it. Having two sets of OLED's for every mile per hour is way over engineered but I love it.
This is exactly the type of engineering I love BMW for. The feature is nearly unless if you have headsup display because the same info is show there and there's no reason to even look at the cluster. But even so... Having a full LCD cluster display the info isn't impressive. 200+ OLED's to serve this minor display function 95% of people won't notice is amazing.
Here's a video of it working in the E90. These were single color LED's. The F10's have both green and amber. Look at the way the light LED's move up from the bottom when the cruise control is turned on. Really shows how many there are
      08-19-2015, 08:27 PM   #79
BMWrules7
LOL! You've been fooled matey.
I hate to be the one to break it to ya!
There are not hundreds of OLEDS.
There are just a couple of OLEDS attached to a spinning disk or otherwise kinetically driven pointer.
Although, I am sure the BMW engineers involved with the development of the CC display would be proud to know they got you to believe it was really hundreds of OLEDS.
The giveaway is the fact that the spinning disk/kinetically driven pointer fails to line up at demarcated speeds each time. Also, OLEDS would always be perfectly aligned. That's one thing I now like about the digital cluster, it always lines up since it consists of pixels.
      09-22-2015, 03:48 PM   #80
F10_520d
F10_520d's Avatar
Drives: F10 - 520d
Post Brand new 6WB Kombi retrofit + updated Psdzdata
Hi all,
Have just recently purchased a brand new 6WB Kombi for retrofit. However, while trying to inject CAFD files for coding (following the threads from ShawnSheridan), I have realized that the latest PSdZdata version that I have available (v54) became outdated and therefore wasn't able to find and code. Seems that there is a new update from August 2015 so called v.3.56.3 which should contain CAFD / SWFL files needed.
I would highly appreciate if someone could help here, as I'm already a bit anxious for being able VO code such retrofited Kombi and see the results!!!!
Thanks a lot to all of you posting such usefull information about retrofiting and understanding our bimmers, specifically for ShawnSheridan from which I've already read thousands of interesting pages.....
Best regards,
      10-24-2015, 09:42 PM   #81
sprockie
Drives: 320D
Any change this will come available for the F30?
      10-26-2015, 07:58 PM   #82
snowmuch
Drives: 2016 Macan Turbo
I can get a used 6wb unit from ebay uk for about 700-1300. Can they still code a used unit?
C300->C63->535->S4->M4->Macan->Macan Turbo
      03-03-2016, 07:36 AM   #83
mikekilpatrick
mikekilpatrick's Avatar
Originally Posted by rsyed View Post
the cluster arrived on friday, fitted it yesterday and had it remotely coded. works wonderfully! Thanks to Patryk for the smooth transaction: kept us (there was a second member who ordered it with me from vienna) informed throughout the process!
What is that third blue and white screen. My purchase and install only has comfort and sport mode, the first two screens...
      03-03-2016, 07:57 AM   #84
shawnsheridan
shawnsheridan's Avatar
Drives: 2018 Alpina B6 650ix GC
It is for cars with EcoPro.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      03-03-2016, 08:29 PM   #85
mikekilpatrick
Thanks, I kind of thought that after I posted that question. I can say, for under 2 grand, one of the BEST mods for our cars and bimmertech.net is outstanding at coding it into your car...
      10-20-2017, 02:04 PM   #86
tthuns
Drives: BMW X5m E70
Error after installing 6WB coding esys
Hi all,
Just did an install of an 6WB into an F11 2010. Nothing worked before coding, and I did the following as :
Coding was just a matter of adding 6WB to the VO, changing VO Production date to 1211, and VO Coding DKombi and HU_CIC.
After that The 6WB was working correctly, but got the following errors:
- Lane change warning failure
- Park Assis. Park yourself
- Front-end collision warning failure
- Speed limit failure
Do any one have any suggestion for solving this?
Thanks
      10-20-2017, 05:55 PM   #87
Originally Posted by tthuns View Post
Hi all,
Thanks
That could be the problem. I'm pretty sure BMW wasn't around in 1211...
Sorry... Couldn't resist.
