2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum AC blower cuts out for no reason on F10 after start up
      07-17-2016, 02:24 PM   #1
manilae90
Drives: 2017 520d G30
2006 320i  [0.00]
The AC on my F10 is acting weird. While it has only happened thrice. The AC suddenly cuts out or should I say the blower for no reason for a few minutes and magically runs again. All the AC lights and switches work. The AC indicator still indicates the fan speed and changes when you press the fan speed control but no air is coming out and blower motor is silent. After about 3-5 minutes, the thing sorts itself out and works flawlessly.
It only happens 5 minutes after starting the car and once it sorts itself out, the issue no longer repeats.
Any ideas on what it could be?
      07-18-2016, 05:43 AM   #2
Trian
Drives: 2015 535i M-Sport
My initial thought was battery. How old is the battery?
Second thought was fan itself.
      07-18-2016, 10:15 AM   #3
manilae90
2006 320i  [0.00]
Battery is 3 years old. Car is starting and running fine. It only happened a few times but it usually happens after being parked over night. You start the car, drive away. around 5 minutes into the drive, the AC blower slowly decreases speed and dies for a few minutes then starts back up after 3-5 minutes or so.
The fan speed indicator works showing what should be the real fan speed through the glitch.
      07-18-2016, 10:30 AM   #4
M5Beast_NYC
Drives: 15 M5
You got an F10 in the PI? Nice!! Maybe i can import my car to the PI when the time comes
Anyway, the e46 guys have similar issue and it was found to be the final stage resistor. worth a check om the F10.
      07-18-2016, 10:04 PM   #5
gclions
gclions's Avatar
78
Drives: 2011 550i
It's either the blower or the resistor. Good luck, let me know if you need help.
http://f10.5post.com/forums/showthread.php?t=1213317
      06-19-2021, 10:34 AM   #6
southbound
Drives: 2011 535i
Same issue with F10
I replaced the blower motor resistor on my 2011 535i and when I started the car the air blew completely fine for about 5 seconds and it stopped again.
Any suggestions on what to look at next?
      06-20-2021, 05:53 AM   #7
Surly73
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
