2010 2011 BMW 5 Series Forum F10 Biggest wheel spacer without extended studs |
06-05-2018, 05:25 PM | #1 |
Rep 617
Hi guys. I have a bone stock 535i msport. Stock height, at the moment and will likely go with H&R lowering springs since I liked the drop, with stock msport wheels. Can I get away with a 10mm spacer in the rear without having to buy extended studs? Or is that too much length? I just want to have a nice flush look after the spring install. Thanks.
06-08-2018, 03:04 PM | #6 |
Rep 4,209
I got the ones from Burger Tunning as well. I have 10mm on the fronts and 15mm on the rears. Also lowered on H&R sport springs
More photos here: https://f10.5post.com/forums/showthr...293245&page=14 |
07-06-2018, 03:51 AM | #7 |
Rep 9
I got 10mm in the front and 12mm in the back, and i cant use my oem wheel locks on the 12mm. But on the 10mm they barely thread on. Its fine tho cuz its only one bolt out of 5. I wouldnt recommend using stock bolts on 10mm
07-07-2018, 09:21 AM | #8 |
Rep 1,214
3mm spacers on stock lug bolts are sketchy, 5mm spacers get about 2 threads of engagement into the hub with stock lug bolts. Enough to hold the wheel on for a picture but not enough to drive on certainly.
You want bolt engagement equal to the diameter of the bolt into the hub. Last edited by Stück; 07-07-2018 at 06:37 PM.. |
07-07-2018, 10:15 AM | #9 | |
Rep 4,209
There is a reason why there is 5 bolts and not 4 bolts. Factor mainly such as balance. |
07-07-2018, 04:10 PM | #10 |
Rep 3
I just put some Rohanna wheels on my 535i and I’m not happy with the fit, but kinda worried about adding spacers from fear of wheel coming off while driving, do you guys run spacers with no issues? ( with the extended bolts of course )
07-07-2018, 06:38 PM | #11 |
Rep 1,214
There is absolutely nothing wrong or unsafe about a quality hubcentric spacer with appropriately lengthened bolts.
07-07-2018, 06:56 PM | #12 |
Rep 3
