2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Heated seats too hot
      05-13-2013, 08:58 PM   #1
NavS
Drives: 2018 440i
2018 BMW 440i  [0.00]
2011 BMW 535i  [0.00]
There's three settings right? I'm assuming the one with one LED is the lowest setting. Why the hell does it go to the point of burning my backside? I have to continuously turn it on and off so I don't burn myself. How is this normal? Does three LEDs mean its a lower heat?
      05-13-2013, 09:09 PM   #2
Bmwlvr60
Bmwlvr60's Avatar
Drives: BMW X3 28i
2014 BMW 528ix  [0.00]
2013 BMX X3 28i  [0.00]
My US X3 has 3 settings and the warmest setting is with 3 bars, next is 2 bars and the lowest heat setting is with 1 bar. I won't be presumptuous since you bought a Bimmer north of our border.
2014 BMW 528ix M Sport- Space Gray Metallic, Mocha Nappa Leather, Anthracite Wood Trim. Packages: ACC, DA, DA+, Lighting, Luxury, Prem, H-K SS, SAT, Rear Shade
2013 BMW X3 28i M Sport - Deep Sea Blue Metallic, Sand Beige Nevada Leather, FS Wood Trim, HG Roof Rails, and BMW Apps. Pirelli P7 RFTs.
Packages: Cold, Con, DHP, Prem, Premium Sound, Tech
      05-13-2013, 09:14 PM   #3
TheBingoBalls
TheBingoBalls's Avatar
Unless they changed something, I believe 3 is the highest and 1 is the lowest on the E90 so I'd assume it's the same for the F10.
      05-13-2013, 09:22 PM   #4
NavS
Drives: 2018 440i
I always use the lowest setting (one bar) and it comes on fast which is pretty cool, but it comes on too hot. I've set the heat distribution nearly all to the back and it's still pretty hot. Does the heat tie in with the climate control?
      05-13-2013, 09:27 PM   #5
vdubturbo
Drives: E90, E36, 997
Best heated seats ever. Steering wheel too.
      05-13-2013, 10:24 PM   #6
Boardman
Drives: 2013 550
Once you figure out the 3 bars....there are also settings in the menu to adjust heat levels, more/less back, bottom, etc....
      05-13-2013, 11:03 PM   #7
snj1013
Drives: 2011 528i
The one bar is lowest temperature setting. The settings can be coded http://www.bimmerfest.com/forums/sho...ghlight=heated
