2010 2011 BMW 5 Series Forum F10 (Focals K2)speaker wire repair help! |
01-09-2016, 06:53 PM | #1 |
Rep 14,522
alright tech gurus...need some help here. on my Focals on my doors the wire that comes from the speaker terminals have come off the cone. ever see how it seems like it's partially glued to it than comes off and than soldered to the speaker terminals. i circled in red what i'm talking about. it's just the one wire! if i touch the wire to the cone the audio comes back on. it managed to come off so i'm wondering what to use to make it stick. i tried super glue and that $hit didn't work. anybody have any ideas what i can use?
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg Last edited by lsturbointeg; 01-09-2016 at 07:54 PM.. |
01-09-2016, 06:58 PM | #2 |
Rep 67
You would have to solder it to make a good electrical connection, but it might be a bit difficult getting a soldering iron in there through the basket and managing not to damage or burn/melt part of the cone. I'd honestly contact Focal and explain the situation. That wire should not have come off of the cone. If you can convince them that it is a manufacturers defect, they might do something for you. Good luck.
01-09-2016, 07:06 PM | #3 | |
Rep 14,522
01-09-2016, 07:17 PM | #4 |
Rep 14,522
01-11-2016, 11:05 AM | #5 |
Rep 67
Did the wire actually break? Is the speaker still playing? I thought you meant that the wire disconnected completely from the cone. It shouldn't really matter if it is glued to the cone, the issue is if the wire broken. That would stop the audio. As you can see in your diagram above, those wires don't need to be glued to the cone, they just need to make a connection from the terminal to the voice coil of the speaker.
01-11-2016, 11:53 AM | #6 |
Rep 14,522
The wite is not brokrn. If you look you can see the glue on the cone/wire. Where it's like black smudge if I press the wire down it works. When I let go of the wire i lose audio...weird.
01-11-2016, 08:41 PM | #7 |
Rep 228
If the wire is not broken anywhere, then it looks like you have a cold solder (a loose solder joint) on the terminal. If so, you need to re-solder it.
2011 535i xDrive Black/Black, Michelin PS AS 4
2014 435i RWD Convertible Service Manual: www.newtis.info Part: http://www.realoem.com |
01-31-2016, 10:18 AM | #8 | |
The Flasher
55
Rep 164
Did you manage to fix that wire after? Got me concerned now as i run the k2's. How did you end up mounting/sticking the crossovers to door card, gotta be fair those casings are damn heavy!!
BMW F11 520d M-Sport, Stage2 Remap, Sophisto Grau, Oyster leather, Pro Nav, 20" M5 reps, H&R Sport Springs, Vorsteiner Rep Front&Rear Carbon valance, Quad exhaust Conversion, M5 Grill, Focal Audio |
01-31-2016, 06:09 PM | #9 | |
Rep 14,522
02-01-2016, 04:59 AM | #10 |
The Flasher
55
Rep 164
Thats a bummer with the wire, still if it is working ok perhaps the tape will hold? Not ideal but something. Wish i could of bolted mine to door card, just not possible with the location in our cars, ended up bonding it with four dots in each corner of two part adhesive and hot melt gluing the shit out of it around the edges, dont think shes moving anytime soon. Good luck though with focal , let us know if if you get anywhere with them
02-01-2016, 08:16 AM | #11 | |
Rep 14,522
02-02-2016, 05:13 AM | #12 |
The Flasher
55
Rep 164
Need ur advice i think, im not running any amp at present but have listed a thread on main page and audio section, on the bimmertech amp. Have you any experience with it?
Thats the route im taking i think just cant decide which one? Thanks in advance, and yes ur rite those focals are sweeet
02-02-2016, 08:09 AM | #13 | |
Rep 14,522
