2010 2011 BMW 5 Series Forum F10 Mission Performance : N63tu Stage 2 tune paired with downpipes |
02-29-2016, 02:15 PM | #23 |
1505
Rep 676
Drives: '17 F31 340xi US Spec
We have the MAP calibration for ALL Fxx series, including diesels. So if you choose M5, we still can build you a re-flash with all of the bells and whistles.
02-29-2016, 03:32 PM | #24 |
1505
Rep 676
Sneak peak at MAP sensor calibration. The test car this was performed on is a N63tu 550i. Because this engine uses 2 separate computers that control their respective banks, we are able to show you guys the scaling of the original 2.5bar MAP sensor vs the scaling of a 3.5bar sensor working together. In our setup, for demo purposes, passenger side bank had our 3.5bar overboost sensor and driver side bank had the factory original 2.5bar.
At idle, ~980hpa, the factory 2.5bar sensor had a signal voltage of 1.9volt while the 3.5bar sensor had the voltage of 1.16volt. Being a 5volt reference system this means that the factory MAP sensor can display maximum of 2535hpa(2.5bar) at 4.7v while our sensor can display maximum of 3545hpa (3.5bar) at 4.7v. More pictures and videos will be coming up in the following weeks after we get proper logs on a dyno. On our test car, the sensors are working just perfect. |
03-10-2016, 07:37 PM | #25 |
1505
Rep 676
That was a point of that dyno day The sports display is properly calibrated to flywheel power output.
12-05-2016, 12:46 AM | #27 |
Like No Other.
554
Rep 1,833
Did you guys ever get a virtual 1/4 mile time for the tune?
BMW 550i GT LCI (w/ a VW MK7 daily)
personal IG: http://www.instagram.com/TheBlackGT my work: http://www.instagram.com/CorsaAutoDesign |
1stock5501.50 |
12-05-2016, 01:39 PM | #28 |
Rep 1,719
Drives: 2014 650xi Gran Coupe Msport
How big a job is it to pull the computer for flashing? what is the expected life of the turbos on a stage 2 tune with the downpipes?
2014 BMW 650xi Gran Coupe Msport Black Sapphire Metallic on full black merino leather. 20" M5 343M wheels for summer, 20" 373 wheels for winter with Nokian Hakkapeliitta 8 studded snow tires. M6 CP exhaust with M6 Diffuser and ///M Performance carbon fiber finisher. Mission Performance stage 1.5 and transmission tune.
12-05-2016, 02:15 PM | #29 |
Rep 2,062
Different platform, but are you swapping 3.0/3.5 MAP sensors on the S63 X5M/X6M? The S63 doesn't have MAF and other things that the N63, N63TU and S63TU engines have, so I know it's the odd man out.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's '97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's |
03-22-2020, 02:31 PM | #31 |
N63TU king. Quickest 550 ever
Rep 17
03-22-2020, 02:33 PM | #32 | |||
Rep 17
04-04-2020, 10:03 AM | #33 |
Rep 489
They dont care about us anymore . Save your money and go bm3 I have trans and stage 2 dme tune and it's been nightmare. They argued with me saying my trans was tuned and inky after I left message indirectly saying would get rid and do chargeback did they log in and check and turned out that my trans wasnt tuned and took him 2 hrs to figure out what was going on but apparently was issue with my cars software version and it was in backup mode cause of some issue with the flash
04-21-2020, 12:55 AM | #34 | |
Rep 37
