2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications N63 ECU Flash Tune
      10-27-2016, 11:45 AM   #1
krautmeister
krrrraaauuuuut
krautmeister's Avatar
Drives: G12 750i X Drive M-Sport
G12 750i  [0.00]
N63 ECU Flash Tune
Please bear with me with some noobish questions.
So I got together with MavRick and I drove my car and his car back to back. He has the Dinan tune on his and our cars seem to be very close in performance.
I bought preowned so I am unsure if there is a tune on the car already. Certainly it is not a piggy back.
Now the issue is, since I took my car in for dealer service and a software update, and now it feels "slower" than before. Now, there are a slew of performance robbing ailments that may exist coincidentally but I am curious if a dealer would reflash ECU with a software update? I'm assuming the software update (I asked for the steer ahead TSB) is independent from the ECU?
Another question, if indeed I have a Dinan tune, is there a way to confirm with Dinan by way of VIN?
(Current) G12 750i X Drive / M-Sport / LOADED
(Current) 997 Turbo / 6MT / HRE FF01, Land Rover LR3 - Overlanding Family Adventure Shed, E60 525i - "family beater", Alfa Romeo Spyder Veloce - garage art
(Gone) F10 550i / M-Sport, D2 Audi S8, AP1 S2000, Z32 300zx, S13 240sx
      10-27-2016, 12:16 PM   #2
badblack550xi
badblack550xi's Avatar
yes Dinan tune is attached to a VIN
2011 550i RWD 60-130 7.35
      10-27-2016, 03:37 PM   #3
Stück
Stück's Avatar
Drives: F15 X5, E46 330i, R56 Mini.S
When the dealer flashes ANY module, ISTA-P will program the ENTIRE car.
Whatever tune was on your DME was likely overwritten with factory software.
Contact Mission Performance if you want a real solid tune on your 550i.
      10-27-2016, 03:59 PM   #4
krautmeister
krrrraaauuuuut
G12 750i  [0.00]
So if indeed I have a Dinan or other tune, and he dealer erased it, do any of the tuners provide a "reflash" complimentary or reduced rates?
      10-27-2016, 05:29 PM   #5
Stück
Stück's Avatar
You'd have to explain the situation to them, but if they are a Dinan dealer they should be able to do it for you at no cost IMO.
Its not like they had a choice, even if they knew ahead of time that you had a tune on the DME. ISTA-P doesn't ask, care, or allow a work around. It just flashes any/all modules reporting an outdated version to the highest software versions.
      10-28-2016, 03:41 PM   #6
MattPro
MattPro's Avatar
Drives: '13 F10 550iX, '91 E30
He's not TU so Mission won't do it
Thanks,
Matt
2013 F10 550iX Carbon Black/MSport
BMW Fault Code DB
FSociety3812.50
      10-28-2016, 04:40 PM   #7
MavRick
MavRick's Avatar
688
Drives: My Wife's M
call Dinan and give them your VIN. if you have their flash, then you can take it to United in Gwinnett and they will re-install for you, gratis. it WOULD be interesting to try that same test on your car, now, if the flash was indeed wiped. maybe it would show accurate boost...
      10-28-2016, 05:55 PM   #8
krautmeister
krrrraaauuuuut
G12 750i  [0.00]
So bad news.... Dinan ran my VIN, never was flashed.... bummer. I guess its either a performance malady or my foot just got used to the power??? funny how perception can become reality.
On the upside, my car has the ability to bump the power!!! I was afraid if it was indeed tuned, then I got used to the power, I can only go down a really deep rabbit hole to fulfill the power greed!!!
Looks like a piggy back or tune may be in order.
      12-05-2016, 06:37 PM   #9
krautmeister
krrrraaauuuuut
G12 750i  [0.00]
So I just was poking around under the hood tonight. I've been having a "whistling" sound as of late and I chalked it up to cold weather for no rational reason. I looked at the passenger side intake pipe, and it was not totally sealed! The rubber joint was not even completely on the plastic oval tube!
Could a leak at this point give a bit less power? I'll confirm by butt Dyno in the morning.
      12-06-2016, 04:06 PM   #10
MattPro
MattPro's Avatar
Yes, definitely could. That's post-MAF so any air entering through that leak is not metered air. We have a very complex load calculation system (2 MAFs and 4 MAPs haha) so it's hard to say how much of an effect it will have but definitely not good!
Thanks,
Matt
BMW Fault Code DB
      12-06-2016, 05:03 PM   #11
krautmeister
krrrraaauuuuut
G12 750i  [0.00]
I'm still on the fence on whether i have a real performance reduction.... never benchmarked the boost or anything prior to my "feeling" of lower power.
Just bought JB4 today so we shall see!!!!
