2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Code 122104
      12-08-2016, 07:49 PM   #1
747flyboy
Drives: 2008 M3 2012 550i M
Code 122104
Has anyone seen this code 122104 "No Description"
Randomly appears when car is warm.....No description next to code.
It does it at startup during drive at odds....very strange
      12-08-2016, 08:41 PM   #2
MattPro
MattPro's Avatar
Drives: '13 F10 550iX, '91 E30
According to Rheingold the code could be from an open circuit or disconnection for blow-off valve 2. I could check the connector to make sure it isn't loose or doesn't have coolant leaking on it or anything.
Thanks,
Matt
2013 F10 550iX Carbon Black/MSport
BMW Fault Code DB
      12-08-2016, 09:25 PM   #3
747flyboy
My dear friend Matt,
You are a genius! There is a good possibility coolant leak in the area. Cannot wait for day light for visual inspection. Would you have schematic or description on Blow off valve 2 location?
You are the man.....Did you you get your charge pipes by any chance? I am willing to hand you mine...Gratis for friendship and adoration......
      12-08-2016, 10:00 PM   #4
747flyboy
Matt!
Any recommendations on which Rheingold diagnostic software to buy?
      12-08-2016, 10:57 PM   #5
MattPro
MattPro's Avatar
Here's the connector circled in red. I would first check if it is loose--that is most likely.
View post on imgur.com
I have not gotten any charge pipes yet, I will be in touch
And regarding Rheingold, I have a download link I will PM you either tonight or tomorrow if you computer dies shortly.
Thanks,
Matt
BMW Fault Code DB
