2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Offsets? 20x9 all around
      12-28-2012, 02:53 AM   #1
ryan970
ryan970's Avatar
Hong Kong
164
Drives: Tiag 328i,DGM F10 550
So I was wondering what offsets i should go with 15,20 or 35 in the front and back. Also its for a x drive so i dont want go with a staggered setup.
08 TIAG 328i
13 DGM 550 x drive
      12-28-2012, 05:45 AM   #2
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
Out of those three, I'd get 35.
      12-28-2012, 04:20 PM   #3
ryan970
ryan970's Avatar
Hong Kong
164
All around or should i go 35 on the front and something else on the back?
08 TIAG 328i
13 DGM 550 x drive
      12-28-2012, 05:29 PM   #4
remmib
remmib's Avatar
Norway
1568
Rear too. OEM are ET33 on 8.5 wide wheels, so ET35 on 20x9 will be pretty close to that.
      12-28-2012, 06:26 PM   #5
ryan970
ryan970's Avatar
Hong Kong
164
Well i have the m sport pack so its 19x9 and i wanted there to be less of a gap.
08 TIAG 328i
13 DGM 550 x drive
      12-29-2012, 01:56 PM   #6
remmib
remmib's Avatar
Norway
1568
But I believe F10 with xdrive in the US has staggered wheels, so aren't the rears 245/40/19 too?
      01-02-2013, 11:01 PM   #7
ryan970
ryan970's Avatar
Hong Kong
164
Originally Posted by CEWONE View Post
I have a 535 xdrive that didn't come with a staggered set-up, and i don't know if you had a choice. I'm currently sitting the 20's i had on my e60xi that was 9'' wide with a 35 offset all around because i didn't want xdrive problems.
when i installed the front wheels I had to use 3mm spacers to clear the brake calipers, and i dunno if it's because of the Xtreme concave wheels. So i would go with lowest ET32 front which is the lowest offset you can use for the front and the rears will fit with no problem with a ET35 offset.
on www.streetdreams.org the offset specs for the F10 is ET32-40 front and ET35-40 rear and that all depends on the width and the style of rims you buy as well. the tires are 245/35/20 all around.
Thanks, that was really helpful.
08 TIAG 328i
13 DGM 550 x drive
