2010 2011 BMW 5 Series Forum F10 FS: 17" x 8" Rial Salerno Wheels with Bridgestone Blizzak LM-32 Snow Tires |
10-11-2017, 05:18 PM | #1 |
Rep 87
Bridgestone Blizzak LM-32 Snow Tire Package Set of four (tires and wheels) in excellent, LIKE NEW condition High Performance Winter Tires for BMW's 225/45R/17 Mounted on Rial Salerno 17 x 8 wheels - no curb rash on these wheels They will fit most BMW's with 17" & 18" wheels (Bolt pattern 5-120) - 5 series; 3 series; 1 series - including X5; X3 and X1 FYI - I did "minus sizing" for the winter snow tires. My car had 18" summer rims "Minus sizing" for the winter uses smaller, narrower tires so that you drive with better control in the snow. Includes: -TPMS for each wheel -Valve Stems for each wheel -Lug bolts for each -Rial Center Caps for each Have 8/32's of tread life left! They were on my 2011 BMW 335xi sedan These tires have the snowflake on the mountain seal - meaning these are top performers in snow and ice. Purchased new from Tire Rack for $1500. Selling complete package for ONLY $750! Driven only 8 months and now have 8/32nds of tread. They have two or three winters left in them Local pick up ONLY - Mineola (Nassau County, NY) Thank you for your interest Call or Text: 516-429-3434 Or message me on this board. Last edited by bboomer; 10-25-2017 at 08:42 AM.. |
10-14-2017, 09:48 AM | #3 | |
Rep 87
So 225 x 55% = 123.75...which is the height of the sidewall. My snow tires are 225/45/17, so the sidewall will be (225 x 45%) 101.25. In addition, which F10 model do you have and what year? With that information I can find out if these tires will indeed fit your vehicle. I'm most certain they will. Thank you for your interest. |
10-14-2017, 10:07 AM | #4 | |
Rep 87
So just over 3/4 inch smaller. These tires would fit and your car would handle a bit tighter do to a lower sidewall! Taking corners would be fun. Again, thank you for your interest. BB |
10-23-2017, 10:56 AM | #7 |
Rep 997
Forget about "tight handling" those tires are significantly smaller than stock spec. The diameter is almost 6.5% smaller which will make your odometer count more miles compared to stock wheels: Stock=777 Revs/Mile, yours=832 Revs/Mile.
Also are you sure that those wheels will clear the brakes? |
10-23-2017, 08:15 PM | #8 |
Rep 87
Originally my 2011 335xi came with staggered high performance wheels:
225/40-18 Front and 255/35-18 Rear These snow tires are "minus sized." 225/45-17 They absolutely fit over the brakes! |
10-24-2017, 05:16 PM | #9 |
Rep 72
As you've said, your 335xi
the F10 5 series takes a 245/45/18 and the minus size is 225/55/17. It appears your tires are smaller in diameter. I would have considered them if they were the right size, being that I am in Nassau county as well. Check it here : https://tiresize.com/comparison/ |
10-24-2017, 10:53 PM | #10 |
Rep 87
I just checked the difference between the front 225/40-18 and the snow 225/45-17 on "tiresize.com/comparison" and found that stock has 828 revs/mile and the minus size snows have 832 revs/mile...this is a 0.48% difference...pretty insignificant.
10-24-2017, 10:53 PM | #11 | |
Rep 87
10-25-2017, 07:14 AM | #12 |
Rep 997
Dude I'm not really sure what you are trying to do, but this is F10 for sale Market Place and the wheels you're trying to sell are significantly smaller vs. stock F10 spec. which is 225/55/17 at 777 Revs/Mile. (FORGET ABOUT YOUR 335xi IT'S A DIFFERENT CAR)
10-25-2017, 08:37 AM | #13 | |
Rep 87
I apologize for my mistake. I will remove this FS post. |
