2010 2011 BMW 5 Series Forum F10 Eibach Front And Rear Sway Bar Kit for xDrive |
05-22-2020, 07:55 AM | #1 |
Petrolhead
441
Rep 810
Looking to upgrade the stock sway bars when I mount the K3s but as with every aftermarket upgrade for the F10 xDrive, there doesn't seem to be a lot of options.
ECS Tuning has this Eibach sway bar kit listed as compatible with the 550i xDrive, but it isn't the case in Eibach's own catalog. Anyone can confirm from experience whether it's actually compatible? https://www.ecstuning.com/b-eibach-p...-20-022-01-11/
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) |
05-22-2020, 11:05 AM | #2 |
Rep 1,873
I have a set of H&R sways in my "inventory".
The rear end of RWD or AWD is identical, so that was never really in question. At the front, the bar seems to fit and function fine. A little bit of trimming of the under tray was required but that was true in the RWD instructions as well. H&R also says explicitly that they are NOT for X-Drive. There's always the risk that the reason why is non-obvious. It fits fine, but maybe some component somewhere doesn't have sufficient strength for the forces involved and a really expensive or hazardous failure could take place. I have no idea but would be interested to know. For reasons of balance, I don't have the H&R front on the car any more, but the rear has been on for years. I believe the H&R and Eibach offerings are essentially identical except for colour. |
05-22-2020, 03:09 PM | #3 |
Rep 234
In my experience, the stock bars are fine with the KW3. The aftermarket bars will inhibit independent movement of the suspension.
Seriously, try the stock bars first. Good luck. |
05-22-2020, 03:17 PM | #4 |
Rep 14,521
also wanted to note that's there now quite a few of us members running the upper strut bar with nice improvements. tho a few of them had installation issues some of us did not. this could be an alternative. i'm RWD and still running stock sways and after the strut bar upgrade don't feel the need to upgrade the sways. keep in mind i'm on KW's so i'm sitting pretty low. maybe if you are completely stock it might be different since you're sitting higher?
05-22-2020, 04:31 PM | #5 | |
Rep 1,397
lsturbointeg9163.00 |
05-23-2020, 12:16 PM | #6 | ||
Petrolhead
441
Rep 810
05-27-2020, 08:15 AM | #7 |
Rep 392
[QUOTE=spielnicht;26215326]
x2!
535D Xdrive DUDMD Stage 1
x5d e70 DUDMD stage 2 tune |
05-27-2020, 05:41 PM | #8 |
Rep 14,521
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg Last edited by lsturbointeg; 05-27-2020 at 05:46 PM.. |
05-28-2020, 06:13 AM | #10 |
Rep 9
thank you lsturbointeg, just bought one =D looks like theres alot of clearance from your angle. i got a k&n air intake already and i'm sure i can fit a carbon fiber engine cover in the future
05-28-2020, 06:29 PM | #11 |
Rep 14,521
No problem! Post pictures when you do. Interested if you have to modify the K&N gasket that goes around the box. Yup, looming into buying g the cf engine cover here shortly. Which one are you looking at?
05-28-2020, 11:25 PM | #13 |
Rep 14,521
do you have a link to the ER one? i didn't know they had one
05-29-2020, 06:02 AM | #14 |
Rep 9
https://www.etektuning.com/er-carbon...-bmw-n55-3-0t/
unfortunately it's a 1x1 weave, probably why it's so cheap. They don't have any on ECS probably because of the pandemic. i would like one as OEM as possible with the bmw logo |
05-29-2020, 08:07 PM | #15 | |
Rep 14,521
