2010 2011 BMW 5 Series Forum F10 Help! The idling and stall. 118002 102001 |
08-07-2022, 12:51 AM | #1 |
Rep 14
https://youtube.com/shorts/_NIdyRbLrN8?feature=shareHi everyone. I am new member in this forum. I am very happy to have my f10 n20 520i. I love her more than my wife. I have upgrade everything, FTP charge pipe, boost pipe and turbo inlet pipe. Well! The nightmare is coming when I upgrade to MST intake. The car is idling and vibrating when I start the engine. Sometimes it will stall! The rpm jumps and downs to under 500. I tell this issue to my mechanic and he was replace the MAF sensor, coil and spark plug. The problem still. The code reader pop up 2 codes: 118002 and 102001. Any one can help me and give me a solution. Thanks!
08-07-2022, 03:06 PM | #2 |
Rep 262
You should check your MAF is installed correctly, ensure it's not installed backwards. Then check Crankcase hoses, make sure they are all connected properly and also not cracked. Good luck
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
Ngwing125f10n206.50 |
08-07-2022, 08:16 PM | #3 |
Rep 14
Thanks! YTD I put the stock intake back. I check there is no crank. I will check the MAF insert correctly. Keep update!
08-08-2022, 06:16 AM | #4 | |
Rep 14
550bye1389.50 |
08-11-2022, 07:12 PM | #5 | ||
Rep 14
