03-27-2019, 06:54 PM | #1 |
Rep 3
Rear Tires 2011 550i
I really dislike the rubberband look of my current tires. Looking for a bit more cushion. Currently have 275/30/20 on my rear. Do you think I could jump to 275/40/20s? Asking for a friend...
03-27-2019, 08:33 PM | #2 |
Rep 7,497
A simple tire size calculator should give you the answer you need....they can easily be found by typing "tire size calculator" in a google search box.
You need to compare the rear and front axle overal rolling circumference and diameter...they should remain within 3% (+/-) of each other to prevent ABS/traction control/odometer/speedometer and AWD system (if so equipped) issues. You may also want to check if there will be any suspension rubbing or too much "poke" ( a higher wheel aspect ratio from 30 to 35 shouldn't cause this issue...but I'd definitely check going from 30 to 40, though). Here's a good site for checking the aforementioned: www.willtheyfit.com
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 03-28-2019 at 10:00 AM.. |
03-28-2019, 02:53 PM | #5 |
Rep 14,521
other's have switched from 20's to 19's as well
Tags |
tire 20s, wheels, wheels 20 |
