2010 2011 BMW 5 Series Forum F10 4U1 - Ceramic Controls Retrofit |
07-04-2017, 01:07 PM | #1 |
Rep 1,214
Another one of those mods I've wanted to do since I first sat in a car with ceramic controls. They just look and feel so much nicer than the pearl chrome stuff BMW has adopted lately (in in the new cars bathed in)
I was making a salvage yard run the other day and came across a 2011 750Li with ceramic controls. It had the earlier (wrong) iDrive controller so thats of no use to me, but I snagged the shifter and the Radio/AC control panel. Neither the shifter itself or the control panel would work in my F10 though. Different connectors, shape, size yada yada... I was willing to bet my money at the door though that the knobs and shifter trim would swap over once disassembled. First off, tear down on my own car (takes about 2minutes to do this) Note the shifter trim was already swapped over at this point. Back to that bet... I was sort of right. The shifter trim swapped over directly, no problem. The radio knob swapped over directly. No problem there. The dual temperature knobs on the other hand uses different types of rotary encoders, and as a result were not compatible nor could they be directly swapped over. The F10 uses a castellated encoder, where as the F01/F02 uses an internally notched magnetic wheel. Now the knob part itself though... was the same size and shape. I carefully pried the encoder pickups off the knobs and swapped them over as needed. I glued them with a few dabs of quick set epoxy. Once snapped back into the housing its all trapped anyway. Finished product: Now I just need a ceramic NBT/Touch iDrive controller to complete the set. |
07-07-2017, 10:13 AM | #2 |
Rep 62
Great work man! I did a double take in your car after drooling over your 6WB to see if you had ceramic controls too!? Even the 2014+ update to controls looks better than the pre-LCI that I have, ceramic controls are icing on the cake!
07-19-2017, 01:35 PM | #5 |
Rep 196
Thats good to hear.
I'm in the same boat as you, having to swap over trim on my CIC controller and possibly on the radio/heating control panel - although I do have an F10 radio/heating control panel. So it may work depending on software level. Would you be able to describe how you removed the trim from the gear stick? To give me a head start. Thanks |
07-19-2017, 02:56 PM | #6 | |
Rep 5,357
07-20-2017, 04:06 AM | #7 |
Rep 196
Many thanks ezaircon4jc
Appreciate the guidance. I'll post a thread on the CIC controller tear down and refit when I have my T6 torx parts and find the time, as it will be of use to others. |
03-30-2019, 03:32 PM | #8 |
Rep 590
05-03-2019, 11:18 PM | #9 |
Rep 590
05-05-2019, 12:08 AM | #10 |
Rep 590
