2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding 12v power
      10-28-2013, 08:40 PM   #1
T-Man
Drives: 535i M Sport
I'm trying to find the best spot to tap into a 12v power source that's active only when the car is on. Everything I'm finding in the truck area is hot all the time. Even the truck cigarette lighter always has power. What have people been tapping into??
      10-28-2013, 10:59 PM   #2
///SAL
///SAL's Avatar
Drives: 2014 ///M5 ZCP
What are u hooking up?
      10-28-2013, 11:45 PM   #3
T-Man
Gthaus Meisterschaft GTC module box. It's the control box that gives power to the valves.
      10-29-2013, 05:44 AM   #4
v12
Drives: F10
The various 12V sockets in the car lose power when or a few minutes after you lock the car and get it back when you unlock it.
You could also tap right into the fuse box.
      10-29-2013, 09:38 AM   #5
///SAL
///SAL's Avatar
The best thing to do to avoid warranty problems is buy " add a Circuit" and tap into your homelink fuse that will work perfectly. I have the same setup for my laser jammers and i works great. Plus if one day u forget it on you loose power, but if u do it this way once u turn car off that power will cut off. Gl
      10-29-2013, 01:04 PM   #6
T-Man
Thanks I found one
      10-29-2013, 02:31 PM   #7
///SAL
///SAL's Avatar
It will look like this u could buy it at any auto part store for Round 5-7 dollars. in my opinion and what i did is cut off the blue plug and splice both wires together to get better connection. Now check your fuse before you buy it, they come in mini or large so check that and also call the company up and ask what amp does the unit need ( to avoid melting the wires or blowing out the fuse). Gl
      10-29-2013, 11:24 PM   #8
T-Man
Thank you for all your help. That's the unit I got today from AutoZone it was $7. Were you able to plug into a open slot or did you plug into a occupied one. I'm trying to find a open one but the fuse diagram from BMW is not user friendly at all. Empty spots are not labeled and the taken spots are labeled with pictures not words.
      10-30-2013, 12:39 AM   #9
///SAL
///SAL's Avatar
No problem glad i could help, i tap into my homelink which i knew 100% there will be no power after car shut down. But like u said if theres spares thats great, but just double check it wont draw power after shut down. I think i got the a pic of your fuse panel each symbol will tell you which slot number is your fuse, and on the bottom it tells u what amp is fuse is drawing. But like i said before contact the company and ask how much amp do u need to run the kit. Goodluck let me know if u have any problems.
      10-30-2013, 12:40 AM   #10
///SAL
///SAL's Avatar
535xi
