2010 2011 BMW 5 Series Forum F10 Help Please - 530 Diesel Slow to Warm Up |
10-26-2012, 10:14 AM | #23 |
Rep 150
I have had a number of BMW`s (only 2 were purchased from TW). I have found the service to be second to none and nothing is too much trouble. As for buying a car from them, there is no loyalty whatsoever, but this works both ways...for me it`s all about who can offer me the best price.
10-26-2012, 03:57 PM | #24 |
Rep 619
I appreciate this isn't apples with apples, however my 520D takes less than 3 miles max to get to 100°C, even in winter (0-5°C ambient), an that's driving gracefully.
Sunset Orange G20 330e xDrive M Sport Pro - Tech/Pro Pack, Park Assist Plus
Bluestone G30 M Sport - Gone to Stud Alpine White F10 M Sport - Gone to Stud |
10-27-2012, 07:58 AM | #25 |
Rep 5,023
well I looked at this this morning.
3C (the lowest temperature I've driven the car to date) and it took around 16 minutes / 8 miles to get to around 100c. Car was set up in Eco pro mode with gentle driving. |
10-27-2012, 10:39 AM | #26 |
Rep 15,858
Thinking about this a bit more, it is difficult to compare results, as we all have varied conditions, add in the fact that different engines have various coolant and engine oil capacities. Plus the diesel models have the PTC electric heater assisting cabin heating. Petrol models don't, so we certainly don't have a level playing field, even to compare engine types or sizes.
From data, I see a 520d has a 5.2-litre sump capacity, the 535i has 6.5-litres, the 530d 7.2-litres, so there is quite a large difference in heat absorption, due to that alone. Another factor is the mpg (or for time, litres/hr) we are achieving during warm up. That will have a major influence, as after all, it is waste heat that we are using to warm up. HighlandPete |
10-27-2012, 02:47 PM | #27 | |
Rep 144
I'm certainly not saying bounce on the redline straight after starting the car but drive the car normally in comfort mode (the interior will also heat up quicker that way as Eco Pro turns down the electric heating elements). Go through the gears up to 2/2500 rpm. 8 miles in 16 minutes also suggests urban driving which won't aid warm up times. Best of luck. |
10-28-2012, 06:24 AM | #28 |
Rep 537
Where have you got the info the diesels have PTC heating elements Peter? I'm not saying you are wrong because I don't know but my LCI E61 certainly didn't have them and so far the F11 only produces heat as the temp dial rises (maybe there is an lower temp limit before they work if they are fitted). I cant see them on Realoem only electric pre heaters on 4 zone A/C cars.
10-28-2012, 11:10 AM | #29 | |
Rep 15,858
http://www.realoem.com/bmw/showparts...48&hg=64&fg=40 HighlandPete |
10-28-2012, 12:32 PM | #30 |
Rep 537
That's what I saw. I think that's only for cars with 4zone heating. Its available on petrol cars too and I think the electric heating elements are for trimming the heating when you have four seperate zones commanding different temperatures.
I would be supprised if the dervs do have PTC elements as they warm up so quick now. They were removed off the later E60s and these warm up faster than those. |
10-28-2012, 12:45 PM | #31 | |
Rep 15,858
For example F20 1-series and 3-series F30 diesels have them, and they don't have a 4-zone system. http://www.realoem.com/bmw/showparts...77&hg=64&fg=40 http://www.realoem.com/bmw/showparts...77&hg=64&fg=40 HighlandPete |
10-28-2012, 01:45 PM | #32 |
Rep 144
My 520d was pumping heat out of the vents in less than a minute yesterday and that was at +1 degrees.
That would confirm the PTC elements for me (I don't have the 4 zone AC). If its doing that without PTC elements, that is very impressive. |
10-28-2012, 02:30 PM | #33 | ||
Rep 537
Are you assuming they are on the diesel 5 series or have you seen anything to point towards that other than the links above? |
10-28-2012, 02:56 PM | #34 | |
Rep 15,858
BTW, have you got 4-zone? If not just try your VIN, it will tell you do or don't have it. If A900ss could try it as well, we'd see if it is listed on the standard diesel models. Tried my VIN and it says... "Items pictured but not listed are not installed on your vehicle". Part 03 is not on the parts list. HighlandPete |
10-28-2012, 03:12 PM | #35 |
Rep 15,858
BTW, the reference to the 4-zone system is the part 01, that definitely is in the 4-zone systems. I must find the details and schematics with the air flows. I thought I had them on the laptop I'm using at the moment, but as of yet not found them. Will have to search my backup drive.
If I look at a generic 535i and look for the front PTC element it is not isted, but the parts 01 left and right are listed for the 4-zone. The front element isn't part of the 4-zone. HighlandPete Last edited by HighlandPete; 10-28-2012 at 03:26 PM.. |
10-29-2012, 04:51 AM | #37 | |
Rep 619
10-29-2012, 12:40 PM | #38 | |
Rep 3,016
Along with many other automotive technical technical advances, the radiator slats obviously play a significant part in this improved efficiency. |
