2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Ticking Noise - After turning
      03-03-2017, 10:44 AM   #1
M6NIAC
M6NIAC's Avatar
Drives: 550
Hello, some of you might remember a few months ago I posted about my car having this problem. I took it to the dealer 4 times and they couldn't figure out what was causing the sound and they were having problems duplicating the sound. The 5th time bringing it in I was able to duplicate the sound loud enough for the mechanic to be convinced it needed to be changed. They ended up replacing:
  • Right Front Axle
  • Left Axle Shaft
  • Output Shaft Seal
The noise after that went away and the car was back to normal. Now 5 weeks ago, I started hearing the same noise coming from the same exact area; however, it was light and not loud like before. Each week the noise became more often and louder. Now fast forward to today... I was driving out of my neighborhood and turned left to head down the road. The ticking sound started sounding much louder and noticeable even with my music volume turned up about 40%.
Also before you anyone jumps to conclusions know this please.
The only mod I had on my car during the time it first started was my intake!
      03-03-2017, 11:36 AM   #2
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
It looks like they replace all unnecessary parts have them replace wheel bearing
      03-03-2017, 12:02 PM   #3
CV joint???
      03-03-2017, 12:27 PM   #4
M6NIAC
M6NIAC's Avatar
Drives: 550
CV joint???
That's exactly what I was thinking, but I wasn't exactly sure.
      03-03-2017, 05:05 PM   #5
Gregxi
Gregxi's Avatar
Drives: 2014 535xi
Axle is a CV joint. Constant Velocity Axle is the proper term.
I am not looking at a parts diagram for your vehicle but you normally have an inboard side and a outboard side to the CV Axle. When they start to fail they will click as time goes on they get worse, the problem for the technician is which one is the culprit, it's a sealed unit so you really can't measure run out or look for signs of wear.
It could be that they replaced the one half of the axle that was bad and the other half was on the way out but not making noise yet.
Most technicians would like to replace the whole thing but the factory will only authorize half shafts and only reimburse the dealer for that.
It wasn't that long ago a CV joint was considered a wear item and not covered under warranty
My guess is that left shaft is only half a shaft
      03-03-2017, 06:25 PM   #6
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
I have he same problem, kinda learned to live with the pain. I want to blame the electronic steering rack. I've had control arms, wheel bearings and bushing replaced and still clicks.
IG: @bmwdoubles
      03-03-2017, 07:44 PM   #7
The whole axle can't be a CV joint. That's like saying a u-joint is a drive shaft...
The rubber-booted part at each end are the CV joints. The solid part in the middle is the axle.
      03-06-2017, 09:21 AM   #8
ruben356
Drives: F13 M6 _ San Marino Blue
I had your same exact problem, same side too. They replaced my hub bearing and this fixed the issue for me. I've also read about braking hardware/caliper causing this for some people. Now I am getting the same noise from my right side when I turn right, talk about pain. At 58K now. Left side was done at about 52K.
      03-06-2017, 10:22 AM   #9
M6NIAC
M6NIAC's Avatar
Drives: 550
It's bullshit and i'm getting frustrated
      03-06-2017, 01:46 PM   #10
cipher5
cipher5's Avatar
Drives: 2020 Donington Grey X3M Comp
Aren't our CV joints under recall?
      03-06-2017, 02:23 PM   #11
M6NIAC
M6NIAC's Avatar
Drives: 550
See that's exactly what I told my service rep, but she stated that it wasn't for models 2013 and newer. Pretty sure it's for 2011-2012 models.
      03-06-2017, 02:43 PM   #12
cipher5
cipher5's Avatar
I just looked it up, you are right, only 2011 F10s
      06-06-2017, 03:48 PM   #13
cipher5
cipher5's Avatar
Did you ever figure this out? I have the ticking noise now too... 2011s are under a cv joint recall and even though mine is a 2011 535i xdrive I used BMW's site to see what was under recall and my VIN didn't show that recall...
I'm supposed to take the car in a few weeks to the dealership, I think I'm out of my CPO warranty now too at this point (if its not a recall), not trying to get raped on repair costs...
