2010 2011 BMW 5 Series Forum F10 310 WHP / 344 TRQ - RaceChip N55 |
10-25-2016, 06:18 PM | #1 |
Rep 465
Hello,
I got a racechip ultimate for my car as I wanted something quick and easy for some power. Install took me 15 minutes and I never worked on a car before. Stock power on these cars at the wheel is seen on average at about 277 WHP and 280ish TRQ. The dyno run that produced the most (blue) was a 5th gear pull. Mods: Resonator delete, KN Filter, RaceChip (F Setting), E85+91oct.
2013 F10 535i M-Sport Alpine White Oyster/Black OEM M5 Exhaust with Resonator Delete Last edited by DigitalNav; 10-25-2016 at 11:31 PM.. |
10-25-2016, 06:19 PM | #2 |
Rep 465
Considering how much more TRQ I feel at 344... i cant imagine the 410+ from MissionPerformance .
Im debating on going to MISSION to get that more power.
2013 F10 535i M-Sport Alpine White Oyster/Black OEM M5 Exhaust with Resonator Delete |
Chase358.00 |
10-25-2016, 06:40 PM | #4 |
USAF Pararescue Veteran
332
Rep 770
I am definitely going with mission, if for no other reason that they can make it so we pass smog. the added power and ability to run e85 mixes will be very nice as well
still, the 33hp gain isn't bad for a piggyback |
10-25-2016, 07:00 PM | #5 |
Dream crusher
984
Rep 2,421
Thats not horrible. Awesome you have some real world data on Racechip for our cars. Nice work!
You stand to gain about 10-15 more whp and 70wtq with mission on your setup for the MP stage 1. Maybe more if you have the 4" outlet on your turbine. Power we need is 375-400 that holds across to redline. Then our cars will pull their weight around on the street. Either way we're hitting peak numbers regardless of tune. Our goal is to hold that power. That's the phase I'm heading towards. If you have the 4" outlet real power can be made with yours on a MP tune.
IG: @bmwdoubles |
10-25-2016, 07:20 PM | #6 | |
Rep 465
10-25-2016, 09:27 PM | #7 | ||
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
10-25-2016, 11:32 PM | #8 |
Rep 465
I upped my setting on the racechip from F -> G. Lets see how it goes. I think once someone does PURE Turbo stage 2 upgrade, I will go that route with MISSION
10-25-2016, 11:47 PM | #9 | |
Rep 1,299
Also does it show you what parameters have been changed? Wondering long term reliability as from post earlier that i have read regarding mission performance touching more parameters then piggy bag to ensure reliability. |
10-25-2016, 11:49 PM | #10 | |
Rep 465
10-25-2016, 11:55 PM | #11 |
Rep 1,299
10-26-2016, 12:04 AM | #12 | |
Rep 1,154
also just out of curiousity why did u decide on the racechip? |
10-26-2016, 01:14 AM | #13 | |
Rep 465
Got Racechip cause no need to splice wires, SUPER easy install.
10-26-2016, 06:02 PM | #14 |
Joint Chiefs of Staff
24171
Rep 190,750
Im not aware of any tune that uses wire splicing anymore?
https://x-ph.com/sale/ Phone number 702-494-9435 |
11-11-2016, 03:39 PM | #15 |
Motiphd
122
Rep 232
OP, Any updates?
2016 535i xDrive M-Sport | 2016 328 xDrive w/Lighting (hers)
2012 VW Jetta GLI 6MT APR Stage 2 (retired) | 2012 VW Tiguan SEL 4Motion (hers/retired) 2012 Acura TL SH-AWD Advance (retired) | 2012 Acura RDX Tech (hers/retired) 2010 Acura MDX SH-AWD Advance (hers/retired) |
11-11-2016, 04:09 PM | #16 |
Rep 465
11-11-2016, 04:49 PM | #17 |
Motiphd
122
Rep 232
Switching from F to G.
11-11-2016, 06:45 PM | #18 |
Rep 465
Just a little more kick, not gonna dyno it again unless i do part swap like downpipe or Mission Tune
01-09-2017, 11:21 AM | #20 | |
Dream crusher
984
Rep 2,421
Sidenote: if someone could figure out how to cleverly remove 300lbs evenly we could get that extra little umph on a launch.
IG: @bmwdoubles |
01-09-2017, 12:04 PM | #21 |
Rep 62
I'm assuming you have a catless dp though right? I have one waiting to be installed once I get through my last maintenance warranty check-in in a couple months and I hesitate adding e85 again since I've heard of it causing damage to the stock cat (which is why I was wondering if OP has had any issue running e85 on stock dp).
01-09-2017, 12:09 PM | #22 |
24171
Rep 190,750
No worries with stock cats but i recommend you only use E85 when you have a tune that can monitor fuel,AFR,etc...
