2010 2011 BMW 5 Series Forum F10 How long does it takes to charge F10 Battery? |
02-17-2017, 06:21 AM | #1 |
Rep 76
Hi all,
I got a message on my 2014 F10, saying Battery low. so I got a 1.25A battery charger, (batterytender plus). my battery is an 12v 105AH . I have been charing it for about 10 hours now.but it is still charging. I just want to confirm to see if this is normal. for the bmw battery, what percentage the idrive system start to give the"charge battery" warning? 60% or 80%? could you please tell me how long does it take usually from first sign of battery low warning to fully charged? thanks!!
I am new here. Thank you for your help!!!
02-17-2017, 08:51 AM | #2 |
Rep 25
Sounds like you have a bad battery or alternator is not charging it. The battery should charge up quickly if the car is running and everything is working correctly.
02-17-2017, 11:28 AM | #3 |
Rep 1,214
A 1.25A "charger" us a maintainer, not a charger. It'll likely take days for it to sufficiently charge.
You're going to want a 30/60/90A charger to actually charge the battery in a reasonable time frame. If you're getting battery discharging messages your battery may be on its way out. Check the production date on the battery, it should be stamped into the negative battery post. 4-5 years is typical max life span. |
02-17-2017, 11:46 AM | #4 | |
Rep 85
02-17-2017, 11:48 AM | #5 | |
Rep 76
02-17-2017, 08:19 PM | #6 |
Dream crusher
984
Rep 2,421
Mine took 24hours on the same charger
IG: @bmwdoubles |
02-17-2017, 09:56 PM | #8 |
Retired US Army/Police Officer
30
Rep 161
Drives: F10 M-Sport, E-92
I am curious on where do you hook the battery tender. I have a 2013 F10 and a 2013 E92 and I have been getting the battery discharging messages in the E92 for the last couple of weeks. Today it wouldnt start. Jumped it off and drove it for about 50 miles. Later it wouldnt start. I drive the cars about once or twice a week. Dont want the battery discharging on the F10 so I am going to get a battery tender for it. On my vette I hard wired the connector to the battery under the hood and just plugged it up when its parked for more than a few days. Looking to do the same for the F10 and E92. Have an appointment Monday for the E92. From my understanding the battery is not covered under the warranty.
318IS-330IC-E90-E92 328i F10 535i M
02-17-2017, 11:05 PM | #9 |
Rep 76
It's been 24 hours. Charger is still in red and solid red only. That means it has not reached 80%yet. Hidden menu shows from 11.9v to 12.1v now (car cold).
Hopeful I will see green light tomorrow. Thanks.
02-17-2017, 11:05 PM | #10 | |
Rep 5,362
EL Jeffe 5611.50 hawkjr130.00 |
02-17-2017, 11:07 PM | #11 |
Rep 76
When did you start the charging ?right after the warning came up?
02-17-2017, 11:13 PM | #12 |
Rep 5,362
With or without. A 1.25amp is more of a maintainer than a charger. I bought a 3amp charger when I discovered that the AGM battery needs a better charger. The 3amp takes bout 12 hours after the message appears.
02-17-2017, 11:40 PM | #13 | |
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
02-17-2017, 11:41 PM | #14 | |
Dream crusher
984
Rep 2,421
The old one https://www.google.com/search?q=bmw....bUnDpgQgjYI-gM
IG: @bmwdoubles |
02-18-2017, 07:22 AM | #15 | ||
Rep 76
Does that mean my battery is dying? Is this also consider okay? Also, the battery charger is in red again after only 3 mins of use of hidden menu system. Thank you again.
02-18-2017, 10:21 AM | #17 | |
Rep 1,214
12.2v at 70F for example is going to be about 35-40% nominal state of charge. Again, how old is your battery? If it is more than 4-5 years old it is likely dying. You can continue to waste time on something that will leave you stranded, or you can replace it with a new battery. Batteries are consumable maintenance items on these cars. Make sure the replacement is of like kind and rating and register it with the vehicle. |
02-18-2017, 01:05 PM | #18 | |
Rep 76
thank you, will check production date.
my car temp is 20F (-6C) . the production date is on the negative post ,right? I will check when I get home.. Thank again!!
02-18-2017, 02:28 PM | #19 |
Rep 15,858
I'll add my observations on battery voltage in the F10/F11.
I use a CTEK smart charger and often the charger indicates I'm running just under the 80% SOC, (short rime in Step 3 bulk charge). Under hood terminal voltage will be something like 11.9 Volts at 10C, ahead of the charge. Even after the charger goes to Step 7, Float mode, and is switched off, the voltage will still only be 12.2 -12.3 Volts. I've not disconnected the battery to read voltage without anything connected. But with the car unlocked and services awake, I've always found the voltage is never what you'd expect to read for a fully charged battery. This is not a recent thing as the battery is aging, but been the same for over 3-years. Plus my previous two BMWs were the same, when winter charging. Not uncommon to read just over 12 Volts at the hood terminals with the car unlocked. I think next time I trickle charge the battery, I'll leave the leads connected after charging. Disconnect the charger, lock the car, let it go into sleep mode and then read the under hood voltage, from the extension lead socket. See what the difference is to the car being awake. |
02-18-2017, 07:29 PM | #21 |
Rep 76
battery still going up
my battery is now at 12.2v (form 12.1v this morning) . battery is still attached to the charger.
it's showing solid green light now, according to the charger, it's fully charged.. have you guys seen this before as well? if I leave my charger on, will this keep going up ? I guess I will find out and report back. please share if you have similar experiences in the past. thank you so much for all your information.
02-18-2017, 07:48 PM | #22 | |
Rep 5,362
