2010 2011 BMW 5 Series Forum F10 Anyone mounted original M5 343M 20" rims on an F10/F11 |
08-11-2015, 08:47 PM | #111 | |
Rep 215
so can you snap a few? :-) Last edited by ep224; 08-11-2015 at 08:49 PM.. Reason: forgot to clarify |
11-12-2015, 12:26 PM | #112 | |
Rep 479
Drives: 11 F10 550xi
I put my 245/285 set up on today with the M5 wheels and life is back to normal. The previous setup was most defiantly throwing a few things off. Uneven roads you could feel some of the tires breaking loose or the traction control trying to take over excessively. I concluded if I ran this any longer my transfer case would be toast. I hope this little trial didn't set me up for any long term issues. maybe if someone could chim in on that. |
11-19-2015, 11:17 PM | #113 |
Rep 11
I'm getting ready to do the same thing with my X drive but 265/295 combination are NOT the same diameter tires so not good for an X drive but 255/295 are same diameter and 245/285 are as well but am still concerned with it looking right for one and two what about rubbing on the rear with 295"s vs 285's (which in PSS is on back order forever) anyone??
11-20-2015, 01:21 AM | #114 | |
Rep 479
11-22-2015, 09:36 PM | #115 |
Rep 11
11-23-2015, 05:48 PM | #116 |
Rep 24
I have been running M5 wheels on my 2013 BMW 550i for the past 2 1/2 years. I got the wheels off the brand new M5 in 2013 right when I bought my car new. I have 255/35/20 on the front and 285/30/20 in the back. I had to use spacers in the front with longer lugs and rear didn't need them. My first set of tires were Michelin Pilot Super Sports and I got 13K miles of them. I am currently using Continental Extreme Contact DWS tires and they are great.
Alpine White | M-Sport | Dinan S2 | M5 Complete Exhaust
11-24-2015, 09:09 AM | #117 |
Rep 479
No, I did not have to use spacers. It is very close to the calipers. I have yet to experience any rubbing or any issues being so close. If you do end up with spacers in the front then you will need extended lugs as well.
11-24-2015, 02:50 PM | #118 | |
Rep 11
11-25-2015, 02:38 PM | #119 |
Rep 479
11-27-2015, 01:37 PM | #120 |
Rep 11
Yea in 2013/14 they changed the caliper in that the long bar on the caliper (wish I had a pic but took my 12 to the dealership and compared) closest to the center of the wheel on mine is dished in and curved if you can visualize, where on a 14 I looked at is just curved and flat not dished in and I assume that's the interference problem on some.
11-27-2015, 02:35 PM | #121 | |
Rep 11
02-15-2016, 06:40 PM | #122 |
Rep 12
Can someone who has mounted these 343 M rims on an LCI 550i with XDrive confirm first, whether they needed the 3 or 5mm spacers and then secondly if you did add either of the spacers, was there enough of the hub left to properly mount the tire?
I have a chance to pick up a set of these this week but don't want to waste my time if they can't be mounted correctly. Thanks a lot |
06-13-2016, 10:00 PM | #124 |
Rep 11
On my 2012 550ix the front calipers are like the first (top pic above) and the 343 M5 wheel will work with out a spacer but its really close, BUT it hasn't caused any problems. I would guess if your caliper its like the bottom pic you would need a spacer but I can only verify what I have. l'll post a pic of how close it. Hope this helps.
06-13-2016, 10:22 PM | #125 | |
Master Of My Domain
89
Rep 669
http://f10.5post.com/forums/showthread.php?t=1099954
RIP: 2015 Black Sapphire Metallic 650i Gran Coupe, 343 Wheels, Michelin Pilot Super Sports 255 F / 285 R, M6 Front Grilles. Coming - M6 Comp. Mufflers, Carbon Fiber Diffuser & Spoiler.
06-17-2016, 04:39 AM | #126 |
Rep 32
guys,
thank you all for the very useful pics! my car is lowered with Eibach Pro-Kit springs and I was wondering whether a 255/295 tire setup on the 343M wheels would work w/o rubbing ? the front is lowered 30mm (1.18") and rear 25mm (0.98"). in addition, I guess, I will need 3 or 5 mm spacers for the front because of the calipers being too close to the wheel. Can I use my stock bolts I am currently using on my 19" 351M wheels? Last edited by BimmerV8; 06-17-2016 at 04:51 AM.. |
06-18-2016, 04:08 PM | #127 |
Master Of My Domain
89
Rep 669
If your car is a 2012 or older you can bolt the 343 wheels right up with no problems, as shown in an earlier post on the 2013 and later cars you will need to use spacers to clear the front brake calipers. You can run 255/35/20 tires in the front, but you'll rub if you run 295's on the rears. I guess the M5's rear axles are slightly shorter to allow 295's.
I'm lowered on ACS springs and am running 285/30/20's on the rears with no rubbing at all. Good luck.
06-18-2016, 05:08 PM | #128 |
Rep 32
Thanks, Chili. However I thought I read some posts mentioning that 295 on the rears went without rubbing. Ok, I certainly don't want to take any risk of buying wrong tire sizes. As it is a xDrive I would only be allowed to drive either 245/285 or 255/295 due to the almost identical circumference.
My car has a production date Sep 2014 and I made some pics of the calipers today as good as I could. Will post the pics tomorrow. |
06-19-2016, 03:09 AM | #129 | |
Master Of My Domain
89
Rep 669
I weighed the options and just went with the 285's. Just bolt them up and go.
06-19-2016, 12:21 PM | #130 | |
Rep 32
in terms of calipers and how they look on my car, I made few pics (right and left wheel)...do you guys think I would need spacers... |
08-05-2016, 11:19 AM | #131 | |
Rep 11
12-02-2016, 05:36 AM | #132 |
24FITcoach
32
Rep 76
I also considering placing a M5 OEM wheel on my 2014 F11 M550d xdrive.
Original tire sizes of M5 are 265/35/20 and 295/30/20 but considering xdrive and needed same wheel diameter the problem is easily solved by the changing the 265 front tire into 255. They are actually 2 solutions as fas as i see Front 245/35/20 Rear 285/30/20 Or Front 255/35/20 Rear 295/30/20 Question is which one is the best, having in mind also having ACS springs installed. I think the 245/285 option is the best because the car is lowered with ACS springs and i want zero rubbing. I drive 50000km/year. I wonder if i need the extra spacers to clear the brake caliper in the front with the M550d F11 A clear picture to compare these tire sizes would be ideal Last edited by Thieutje; 12-02-2016 at 05:42 AM.. |
