2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Don't waste your money on Down Pipes For now
      01-13-2014, 09:44 AM   #1
badblack550xi
badblack550xi's Avatar
Looks like Down pipes will give you lose of power because the ECU cannot be coded for down pipes... so unless you want more sound at current moment you will lose power.
__________________________________________________ _______________________________
A couple of weeks ago *********** published Dynojet results from BMS (Burger Tuning) showing the baseline difference between an N63 V8 in a 550i and the updated N63TU V8 rated at 45 more horsepower in a 2014 550i. The N63TU showed less power than the N63 V8 even though BMW rated it at 45 less horsepower. The caveat is that the 2014 550i had aftermarket catless downpipes and those seemed to be causing a power loss.
BMS did further testing on a 2014 550i that had the stock exhaust pieces in place and the results below 4500 rpm were about the same. Above this RPM though the car without downpipes showed more power. The power once tuned however is about the same between the two.
Here is a Dynojet graph comparing a 2011 N63 based 550i and a 2014 N63TU based 550i both with stock downpipes. The N63TU shows a smoother torque curve and a good amount more torque especially from 2700 to 4500 rpm:
Here are the N63TU tuned values on the 550i with the stock downpipes (transmission shifting issues prevented dyno measurements before 4000 rpm from being picked up:
Here is the tuned N63TU with aftermarket downpipes from before showing slightly more torque although slightly less peak horsepower than the car without aftermarket downpipes:
What is the explanation? BMS states the factory ECU is reducing boost in both stock and tuned form above 5000 rpm. Why? That is anyone's guess. BMW seems to have designed to the ECU to reduce its boost target in that RPM range. It is going to take further tuning to eliminate this and at that point aftermarket downpipes should show gains but as of right now the ECU is reducing boost stock, tuned, downpipes, etc.
source ***********.
2011 550i RWD 60-130 7.35
      01-13-2014, 10:12 AM   #2
Mike@N54Tuning.com
Joint Chiefs of Staff
Drives: 2007 335i, 2015 M3
I think this only applies to the n63tu engine?
Mike
      01-13-2014, 10:24 AM   #3
badblack550xi
Mike
id say both i did not see any large gains with my catted down pipes besides the sound and a little better 1/4 time nothing segnificant... id say all people need is Stage 1 BMS or stage 2 BMS and keep everything else stock unless they are after sound.
      01-13-2014, 12:19 PM   #4
alextremo
Drives: F10 550i
I agree, have been holding off since another member posted before and after dyno showing loss of HP and TQ a couple years back.
The only ones showing gains sith downpipes installed are AA, on their dyno.
      01-13-2014, 12:23 PM   #5
combatbmw
Drives: 20' X3M CP
Yes this is my car with catless.
My car is with Evolution racewerks who built the catless downpipes. They will be putting it on the dyno for more testing this week. Untuned. Because tuned and untuned my car was losing boost and power.
They really think the car is spooling too fast causing ecu to freak out.
At this point. I'm going to keep her he down pipes.. Power loss or not. I can't feel the difference.. Sound is too amazing
And wait for a tune that takes care of this. Because there is no way in hell a car should lose power with bigger downpipes and No cats.
I'll keep you guys posted on dyno numbers.
We are doing catted stock dyno runs and catless this week.
      01-13-2014, 12:52 PM   #6
badblack550xi
You might need a custom Tune that can tweak your editions.
      01-19-2014, 10:27 PM   #7
gragi
Drives: 2011 535i xDr F10 M Sport
I just had my catted DP installed AR brand and combined with the AFE Scorcher I am positive I can feel the difference. Car is fast, very fast actually. I did a comparison(test drive) last week between a 2014 335i stock and mine, I am telling you night and day. I like mine and I don't think there is any loss of power here. (No Dyno).
1996 E36 328i Touring
2000 E46 328Ci
2004 E46 M3 Dinan Exhaust
2011 535xDrive F10 AFE CATBACK, AFE SCORCHER, AFE Performance Air Filter, H&R, AR Down Pipe, ER Charge Pipe.
      01-20-2014, 12:09 AM   #8
scott135i
scott135i's Avatar
Drives: 2020 X5 M50i
He (BBlack) is talking about downpipes on a 550 not a 535...
But anyhow, now that he has full exhaust he will probably say they're worth the money for sound alone.
      01-25-2014, 02:34 AM   #9
combatbmw
Drives: 20' X3M CP
Yes I've confirmed catless dps making car run .75 - 1 points Richer the areas car losses power around 5500 rpms car with catless downpipes around 14af. Stock car near 13.0.
The end. Hope Terry makes a stage 2 that should fix the issue
      05-21-2014, 11:59 AM   #10
shoek
shoek's Avatar
Drives: 2013 BMW 550i xDrive M-Sport
So the conclusion is still that catted downpipes on a 550 doesn't help anything but the sound? Does it reduce turbo lag?
I noticed @badblack550xi was talking about going from catted to catless DP's. So there must be some advantage to them?
2013 BMW 550i xDrive Alpine White [300] | Black Dakota [LCSW] | Anthracite [4CE]
Options: M-Sport [ZMP] | DDC+ARS [ZDF] | Exec [ZDB] | Driver Assist/+ [ZDA+ZDB] | Cold [ZCW] | SAT [2TB]
Mods: MORR VS8.2 + PSS (20" 255F/285R) | ACS Springs | Dinan Stage 2 | StopTech BBK
      05-21-2014, 01:50 PM   #11
badblack550xi
After my car adopted to the catted down pipes my 1/4 got faster and my trap by 1MPH... but i am not going in to a very high boost settings for which i will need catless down pipes...
      05-21-2014, 01:59 PM   #12
shoek
shoek's Avatar
OK, good to know. Do you attribute that just to the standard BMW engine management or did things improve when you went to BMS stage 2 beta?
      05-22-2014, 11:00 AM   #13
E60orBust
Drives: "The Brothers //M-Sport" E90/2
Just to clarify, when you guys refer to catted, you mean comparing stock, catted DPs to aftermarket catless downpipes.
You are not referring to aftermarket catted downpipes and aftermarket catless downpipes?
Down for Maintenance
      05-22-2014, 11:47 AM   #14
badblack550xi
stock to after market...
